... | @@ -68,8 +68,8 @@ Once the IOC is ON, set the parameters as follow: |
2. press ![image](uploads/63aee19d1a96b28be8659638e7e8a838/image.png)
3. if there is no count or a very large DeadTime, change the Threshold to 1 and then back to 0.95; you may need to toggle the Preamp gain to 2.7 then back to 2.5 a few times, until you see counts when pressing ![image](uploads/4a2c9b1262a647258b61d4275d150336/image.png)
4. within the first few hour, the count sometimes drops to zero again: repeat step 2 and 3; once it stabilizes it seems to only rarely have issues afterward.
5. the region of interest (ROI) can be set from the screen (Energy)or with python (see below).
5. the region of interest (ROI) can be set from the screen or with python (see below).
<br>
![image](uploads/92dda36827cbc5fb8667302d8c8f95f7/image.png)
<br>
<br>
... | @@ -105,6 +105,8 @@ mcacounttime(2) # Sets vortex count time to 2s |
3. Put the sample at th=165; you can play with the energy to check for alignment; eg if measuring Ni:
- vortex(865) # center vortex window to Ni-L2,3
```python
- energy(855) # tune energy to Ni-L3 edge => lots of count is on the sample
- mono(845) # go below resonance => counts goes away |
\ No newline at end of file |
