## Warning:
## Warning:
- visible light makes the vortex software (IOC) crash; always turn the vortex off before turning on the light or opening the windows; you will also need to restart the software.
- the vortex is sensitive to visible light so the lamp should be off and windows closed
- if you cycle power or turn on the light, you will need to restart the IOC (software).
- after turning on the vortex, wait 5 min for it to cool down
- always remove the vortex from the detectors when IOC is off (see below)
... | @@ -10,11 +11,11 @@ To control the vortex, you only need the little Vortex tab located in the upper |
## To turn on/off the vortex:
## To power on/off the vortex:
On the gui press ![image](uploads/c452321c3f922b3043653038b09cba06/image.png) or ![image](uploads/21a7b5fefd526aa1c3325e5ffd0f5e58/image.png) <br>
On the screen press ![image](uploads/c452321c3f922b3043653038b09cba06/image.png) or ![image](uploads/21a7b5fefd526aa1c3325e5ffd0f5e58/image.png) <br>
Or in python/jupyter:
Or in jupyter:
```python
```python
mcaon()
mcaon()
mcaoff()
mcaoff()
... | @@ -22,9 +23,11 @@ mcaoff() |
## To turn ON/OFF the software (IOC):
## To turn ON/OFF the IOC (software):
The IOC can only be run from Sneezy (vortex is physically plugged to Sneezy). To log into Sneezy, open a terminal:
**Note: Always turn power ON the vortex before starting the IOC.**
The IOC can only be run from **Sneezy** (which is physically connected to the vortex via USB).
type: sneezy
type: sneezy
type password: IEX*data!
... | @@ -35,39 +38,49 @@ It is a good habit to move this terminal to workspace 4 and rename it VORTEX so |
![image](uploads/4cfe370118e57e4cb21f267f5fcdd988/image.png)
#### To turn IOC ON:
- To turn IOC ON:
[sneezy] vortex_start
#### To turn IOC OFF:
Once you type the command to run, there should be no errors. Common ones are b/c the vortex is off or the USB cable was unplugged.
Type CTRL+C in the terminal where the software was running, or open a new terminal, log into Sneezy and use:
- To turn IOC OFF:
Type CTRL+C in the terminal where the VORTEX terminal; or, open a new terminal, log into Sneezy and use:
[sneezy] vortex_stop
Vortex screen goes all white
#### To check IOC status:
- To check IOC status:
[sneezy] vortex_status
## To start taking data:
To visualize the vortex spectrum, use the Vortex ROIs tab on the bottom right of the RSXS screen:
<br>
![image](uploads/5aeca4312e07be4df9a14cc3f01ce5eb/image.png)
1. In jupyter:
```python
scanmca() # add vortex as a detector in the scan
### To start taking data:
2. set the Preamp gain to 2.7 and then back to 2.5.
2. press ![image](uploads/63aee19d1a96b28be8659638e7e8a838/image.png)
3. if there is no count or a very large DeadTime, change the Threshold to 1 and then back to 0.95; you may need to toggle the Preamp gain to 2.7 then back to 2.5 a few times, until you see counts when pressing ![image](uploads/4a2c9b1262a647258b61d4275d150336/image.png)
4. within the first few hour, the count sometimes drops to zero again: repeat step 2 and 3; once it stabilizes it seems to only rarely have issues afterward
To run in continuous mode, switch the drop down menu from ![image](uploads/82df6a63db833cf440b4a5d256800138/image.png) to a time that matches the vortex acquisition time (typically 1 or 2s)
=> scanmca(scan=False) to remove vortex PVs from the scan
=> scanmca() to put back vortex PVs into the scan
=> screen turns on;
=> set the preamp gain to 2.7 and then back to 2.5
=> press start
=> Sometimes you need to change the Threshold to 1 and then back to the starting value
=> Sometimes after an hour, count goes to zero: set the preamp gain to 2.7 and then back to 2.5
\ No newline at end of file |
