... | @@ -91,7 +91,7 @@ To run in continuous mode, switch the drop down menu from ![image](uploads/82df6 |
```python
```python
mcascan() # add vortex PVs to the scan detector list
**Warning: if the IOC is OFF, you will need to remove the vortex from the scan detector**; otherwise the scan will try (unsuccessfully) to connect to the vortex and will just hang on indefinitely untill the scan is aborted:
**Warning: if the IOC is OFF, you will need to remove the vortex from the scan detector**; otherwise the scan will try (unsuccessfully) to connect to the vortex and will just hang on indefinitely until the scan is aborted:
```python
```python
mcascan(add_vortex=False) # chooses to ignore the vortex and removes it from detector list
