| ... | ... | @@ -66,7 +66,7 @@ scanXAS_BL(E_Ti,mcp=True,m3r=True);plot_latest() |
<br>
# diffractometer
## diffractometer
- m1 = kphi
- m2 = x
| ... | ... | @@ -90,7 +90,7 @@ sample(mysample) # moves to mysample, does not move tth |
<br>
# motor scans
## motor scans
```python
scanx(-500,500,50) # absolute scan (start,stop,step)
| ... | ... | @@ -110,7 +110,7 @@ Clear_Scan_Positioners('Kappa') # remove extra positioner (eg after th2th |
<br>
# srs setup
## srs setup
With shutter close or slit at 0 (faster), 'INPUT OFFSET' set 'ON' and 'UNCAL'
- make sure the count goes down (not up) when closing the shutter! If the count goes up without beam, change the INVERT ON/OFF - as of 2021_2 all of our SRSs are INVERT ON (D3/D4/TEY/mesh)
| ... | ... | @@ -123,7 +123,7 @@ With shutter close or slit at 0 (faster), 'INPUT OFFSET' set 'ON' and 'UNCAL' |
<br>
# mcp
## mcp
```python
MPA_HV_ON()
MPA_HV_Set(2975)
| ... | ... | @@ -140,7 +140,7 @@ roi=4; MPA_ROI_SetUp(535,539,400,400,roi) #set up ROI4 = 400x400 at the center |
<br>
# vortex
## vortex
For detailed instructions see [manual here](https://git.aps.anl.gov/rodolakis/Macros_29id/-/wikis/RSXS/vortex).
| ... | ... | @@ -164,9 +164,9 @@ mcascan(add_vortex=False) # chooses to ignore vortex channels and removes them f |
<br>
# analysis
## analysis
## basic mda plots:
### basic mda plots:
```python
# n1,n2,n3 is a scan number
# d1,d2,d3 is a detector number - see table below
| ... | ... | @@ -190,7 +190,7 @@ fit_centroid(n) # to calculate avg centroid position during scan n |
## nData
### nData
```python
from Macros_29id.IEX_nData import *
| ... | ... | @@ -217,7 +217,7 @@ plt.show() |
## mdaFile
### mdaFile
```python
mydata=mdaFile(1,3) # loads mda scans 1 to 3
mydata.update(4) # loads another scan
| ... | ... | @@ -228,7 +228,7 @@ mydata.header[3].UB # return dictionary of UB metadata |
<br>
# detector number
## detector number
| Detector | Det Number Raw signal | Det Number Det/I0 | Description | PV | Controller |
