| ... | @@ -282,17 +282,17 @@ mydata.header[3].UB # return dictionary of UB metadata |
1. There is no beam.
- Make sure there is beam in the storage ring.
- Check if main shutter and branch shutter are open. Check EPS
- Check if main shutter and branch shutter are open. If any shutter cannot be openned, Check beamline EPS and call stuff.
- Check if ID and mono energy setpoints are consistent.
- Check beam on the exit slit camera from m3r_align panel.
- If there is no beam and piezo voltage is very high (-12V or 40V), try tweak it back to zero.
2. `m3r_align` doesn't work.
- This happens when the code had hard time to determine where the peak was. Try tweak the piezo voltage back to zero and adjust
- This happens when the code had hard time to determine where the peak was. Try tweak the piezo voltage back to zero and adjust m3r pitch.
- check exposure time (t(s)) of the camera.
- When the photon energy is too high (> 2.1 keV) or the mono and ID energies are very different, photon counts can be low. Try increase exposure time (t(s)) of the camera.
3. ID gets stuck.
3. ID gets stuck.
- change mode on the ID screen, wait till it's done, and change the mode back. This will reset the ID.
- change mode on the ID screen, wait until it's done, and change the mode back. This will reset the ID.
