___
___
# content
| ... | ... | @@ -13,44 +14,40 @@ ___ |
- [analysis](#analysis)
- [detector number](#detector-number)
___
___
## detectors
| Name | Description | Ang. acceptance<br>HxV (deg) | Offset | Max tth | Det Num | Norm Det Num (d/I<sub>0</sub>) |
| mesh (I<sub>0</sub>)| Au mesh | 1 cm<sup>2</sup> | n/a | n/a | D31 |n/a|
| tey | drain current | n/a | n/a | n/a | D32 |D36|
| d4 | small diode | 0.25 x 2.5 | 0 | 151 | D34 | D38 |
| d3 | big diode | 2.5 x 2.5 | 24 | 175 | D33 | D37 |
| mcp | area det | diameter = 6 | 13 | 165 | D35 | D39 |
|vortex |fluorescence detector| 1 cm<sup>2</sup> | fixed port @ tth=-155 | n/a | D16 | D49 |
| mesh (I<sub>0</sub>) | Au mesh | 1 cm<sup>2</sup> | n/a | n/a | D31 | n/a |
| tey | drain current | n/a | n/a | n/a | D32 | D36 |
| vortex | fluorescence detector | 1 cm<sup>2</sup> | fixed port @ tth=-155 | n/a | D16 | D49 |
<br>
```python
setdet('d3') # select a given detector (d3,d4, or mcp)
# DOES NOT MOVE MOTORS!
mvtth(90) # moves the selected detector
cts(1) # set counting time to 1s
setgain('d3',2,'pA') # set gain for d3
scaler_cts(1) # set counting time to 1s
d3.setgain(2,'pA') # set gain for d3 to 2 pA
See below for a complete list of signals recorded during a scan and their corresponding [detector number](#detector-number) (Det Num).
<br>
## energy
```python
energy(932) # set undulator (ID), mono, apertures and mirror
polarization('V') # Turns the ID off and then sets the polarization:
# 'RCP', 'LCP', 'H', 'V'
# **need to set energy after a mode change!**
Switch_IDQP('V') # turns on quasiperiodic mode for V polarization
ID_start('V',75) # turns on quasiperiodic mode for V polarization at 75 percent periodic (QP_ratio: 70 - 100)
mono(500) # change mono
slit(100) # set energy resolving slits (and vertical beam size)
| ... | ... | @@ -61,24 +58,20 @@ fit_centroid(n) # to calculate avg centroid position during scan n |
scanhv # scan mono only
scanXAS # scan mono with variable step size; ID stays fix, can be offset with offset arg
scanXAS_BL # scan mono & ID with variable step size \
E_Ti=[[445,455,0.5],[455,468,0.1],[468,475,0.5],[475,480,1]]
scanXAS_BL(E_Ti,mcp=True,m3r=True);plot_latest()
<br>
## diffractometer
- m1 = kphi
- m1 = kphi
- m2 = x
- m3 = y
- m4 = z
- m7 = kap
- m8 = kth
- m9 = tth
<br>
```python
uan(tth,th) # moves th & tth simulatenously
| ... | ... | @@ -89,9 +82,7 @@ mprint() # prints current motor position |
# returns [x,y,z,tth,ktrh,kap,kphi]
mysample=['name',x,y,z,tth,ktrh,kap,kphi]
mvsample(mysample) # moves to mysample, does not move tth
<br>
## motor scans
| ... | ... | @@ -112,27 +103,22 @@ hkl=[0.5,0,0] |
scanhkl_E(E_Ti,hkl,1,scan_ID=True) # energy list, Q, cts, scan_ID = False (fixed ID) or True
Clear_Scan_Positioners('Kappa') # remove extra positioners (eg after th2th or hkl scan)
scan_positioners_clear() # remove extra positioners (eg after th2th or hkl scan)
<br>
## srs setup
With shutter close or slit at 0 (faster), 'INPUT OFFSET' set 'ON' and 'UNCAL'
- make sure the count goes down (not up) when closing the shutter! If the count goes up without beam, change the INVERT ON/OFF - as of 2021_2 all of our SRSs are INVERT ON (D3/D4/TEY/mesh)
- Set gain relatively high for the offset (same as sensitivity or more)
- play with the tweak button one way or the other to get a stable number (ie does not slowly goes down to zero); you might need to play with the +/- for that
- try decreasing the offset gain: if it drops to zero, then go back to previous gain and increase the number; try again.
- the goal is to slowly bring the gain down while keeping a non zero signal; typically a few hundred Hz
- adjust until the final INPUT OFFSET gain should be at least 1 order of magnitude lower than the SENSITIVITY with a few hundreds counts
<br>
## mcp
```python
MPA_HV_ON()
MPA_HV_Set(2975)
| ... | ... | @@ -146,18 +132,17 @@ roi=3; MPA_ROI_SetUp(535,539,200,200,roi) #set up ROI3 = 200x200 at the center |
roi=4; MPA_ROI_SetUp(535,539,400,400,roi) #set up ROI4 = 400x400 at the center of MCP
<br>
## vortex
For detailed instructions see [manual here](https://git.aps.anl.gov/rodolakis/Macros_29id/-/wikis/RSXS/vortex).
```python
vortex(855) # Sets vortex window based upon calibration
mcacounttime(2) # Sets count time for mca and other det to 2s
2 different acquisition modes:
```python
mcascan() # adds vortex channels as detectors in scan detector list (see detector numbers below)
| ... | ... | @@ -168,14 +153,12 @@ mcascan(save_image=True) # same as above + saves mca spectra taken at eac |
# MCA spectra are saved into subdirectories of the scan files / scan#
mcascan(add_vortex=False) # chooses to ignore vortex channels and removes them from scan detector list
<br>
## analysis
#### basic mda plots:
```python
# n1,n2,n3 is a scan number
# d1,d2,d3 is a detector number - see table below
| ... | ... | @@ -189,7 +172,9 @@ fit_mda(n, d, FWHM_guess,function) # 'gauss', 'lorz', 'erf', 'box' |
# xrange=[x1,x2] to fit subrange
fit_mda(n, d, poly_order,'poly')
Custom functions for scattering:
```python
plot_latest() # plot last scan with currently selected detector; use norm=31 to normalize with I0
fit_z() # erf fit for last scan on d3
| ... | ... | @@ -198,8 +183,8 @@ fit_d3() # gaussian fit for last scan on d3 |
#### nData
```python
from Macros_29id.IEX_nData import *
| ... | ... | @@ -225,8 +210,8 @@ plt.show() |
%matplotlib inline # inline plot
#### mdaFile
```python
mydata=mdaFile(1,3) # loads mda scans 1 to 3
mydata.update(4) # loads another scan
| ... | ... | @@ -235,38 +220,35 @@ mydata.header[3].all # return dictionary of metadata |
mydata.header[3].UB # return dictionary of UB metadata
<br>
## detector number
| Detector | Det Number Raw signal | Det Number Normalized (d/I<sub>0</sub>) | Description | PV | Controller |
| Mesh | 31 | n/a | Incident energy (I0) | 29idMZ0:scaler1.S14 | SRS1 |
| TEY | 32 | 36 | Total Electron Yield | 29idMZ0:scaler1.S2 29idMZ0:scaler1_calc1.B | SRS2 |
| D3 | 33 | 37 | Big diode (2.5 deg) | 29idMZ0:scaler1.S3 29idMZ0:scaler1_calc1.C | SRS3 |
| D4 | 34 | 38 | Small diode (0.15 deg) | 29idMZ0:scaler1.S4 29idMZ0:scaler1_calc1.D | SRS4 |
| MCP | 35 | 39 | TFY - analog signal | 29idMZ0:scaler1.S5 29idMZ0:scaler1_calc1.E | MPA |
| MCP ROI1 | 41 | | 50x50 ROI centered on MCP center | 29iddMPA:Stats1:Total_RBV | |
| MCP ROI2 | 42 | | 100x100 ROI centered on MCP center | 29iddMPA:Stats2:Total_RBV | |
| MCP ROI3 | 43 | | 200x200 ROI centered on MCP center | 29iddMPA:Stats3:Total_RBV | |
| MCP ROI4 | 44 | | 400x400 ROI centered on MCP center | 29iddMPA:Stats4:Total_RBV | |
| MCP ROI5 | 45 | | MCP integrated intensity (stats) | 29iddMPA:Stats5:Total_RBV | |
| Vortex | 16 | 49 | TFY - centered on desired energy | 29idVORTEX:mca1.R0 29idd:userTran1.D| |
| Vortex | 17 | 50 | TFY - centered on Oxygen energy | 29idVORTEX:mca1.R1 29idd:userTran1.E | |
| H | 46 | | Miller index | 29idKappa:userArrayCalc1.L | |
| K | 47 | | Miller index | 29idKappa:userArrayCalc2.L | |
| L | 48 | | Miller index | 29idKappa:userArrayCalc3.L | |
| kth | 51 | | | 29idKappa:m8.RBV | |
| kap | 52 | | | 29idKappa:m7.RBV | |
| kphi | 53 | | | 29idKappa:m1.RBV | |
| tth | 54 | | | 29idKappa:m9.RBV | |
| th | 55 | | | 29idKappa:Euler_ThetaRBV | |
| chi | 56 | | | 29idKappa:Euler_ChiRBV | |
| phi | 57 | | | 29idKappa:Euler_PhiRBV | |
| Vortex | 16 | 49 | TFY - centered on desired energy | 29idVORTEX:mca1.R0 29idd:userTran1.D | |
