Skip to content
Snippets Groups Projects
Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Target
  • DM/dm-docs
  • hammonds/dm-docs
  • hparraga/dm-docs
3 results
Show changes
Commits on Source (220)
Showing with 623 additions and 1143 deletions
File added
File added
This diff is collapsed.
"1-BM-B,C"
"1-ID-B,C,E"
"2-BM-A,B"
"2-ID-D"
"2-ID-E"
"3-ID-B,C,D"
"4-ID-C"
"4-ID-D"
"5-BM-C"
"5-BM-D"
"5-ID-B,C,D"
"6-BM-A,B"
"6-ID-B,C"
"6-ID-D"
"7-BM-B"
"7-ID-B,C,D"
"8-BM-B"
"8-ID-E"
"8-ID-I"
"9-BM-B,C"
"9-ID-B,C"
"10-BM-A,B"
"10-ID-B"
"11-BM-B"
"11-ID-B"
"11-ID-C"
"11-ID-D"
"12-BM-B"
"12-ID-B"
"12-ID-C,D"
"13-BM-C"
"13-BM-D"
"13-ID-C,D"
"13-ID-E"
"14-BM-C"
"14-ID-B"
"15-ID-B,C,D"
"16-BM-B"
"16-BM-D"
"16-ID-B"
"16-ID-D"
"17-BM-B"
"17-ID-B"
"18-ID-D"
"19-BM-D"
"19-ID-D"
"20-BM-B"
"20-ID-B,C"
"21-ID-D"
"21-ID-E"
"21-ID-F"
"21-ID-G"
"22-BM-D"
"22-ID-D"
"23-BM-B"
"23-ID-B"
"23-ID-D"
"24-ID-C"
"24-ID-E"
"26-ID-C"
"27-ID-B"
"28-ID-B"
"28-ID-C"
"29-ID-C,D"
"30-ID-B,C"
"31-ID-D"
"32-ID-B,C"
"33-BM-C"
"33-ID-D,E"
"34-ID-C"
"34-ID-E"
"35-ID-B,C,D,E"
- DS service
- runs on extrepid
- DAQ service
- APSU station, runs on ctlsdaqsrv2
- Catalog service
- Processing (Workflow) service
- can run workflows for each file, or for set of files, in real-time
- RT workflow args can be set via PV
- DAQ needs to send burst number (e.g, file 3/10)
- can always request workflow processing on a set of files (post processing)
- need portal that will be able to submit processing job
- need to be able to keep track of processing jobs and their results
- DM/CDB integration plugin
- triggered via CDB:<qrId> keyword
- adds DM-document property, will have metadata catalog URL,
file download URL, metadata key/value pairs as needed
- must be able to associate multiple qrID's
- CDB Document domain
- CDB/DM integration plugin: needs to be able to click on the file to see the
metadata, or to download the file
- DM/SDDS plugin
- triggered by ".sdds"
- reads parameters, converts them to metadata
- Use Case: StudiesSession-20170422
- From CDB perspective StudiesSession-20170422 is an item in the
Documents Domain
- From DM perspective, StudiesSession-20170422 is an experiment on an APSU
station
- When collecting DAQ data, DM will automatically asign all files to be
part of the StudiesSession-20170422 experiment
- DM/CDB plugin will add DataFile property to StudiesSession-20170422 for
each file
- CDB/DM file property handler will be able to display DM metadata (URL link)
and download file; later, it may be be able to submit processing job
to DM processing service
# Need 1 terminal on DAQ node, 1 terminal on HPC node and 2 terminals on DS
# node
# SCENARIO 1: BASIC UPLOAD
# ssh -X dm@dmstorage: start services
cd /opt/DM/dev
source setup.sh
./etc/init.d/dm-postgresql start
./etc/init.d/dm-glassfish start
./etc/init.d/dm-mongodb start
./etc/init.d/dm-ds-web-service start
./etc/init.d/dm-cat-web-service start
# ssh -X dm@dmdaq: start services
cd /opt/DM/dev
source setup.sh
./etc/init.d/dm-daq-web-service start
# ssh -X dm@dmhpc: start services, check NFS
cd /opt/DM/dev
source setup.sh
ls -l /net/dmstorage/opt/DM
# dm@dmstorage: check directory content on the storage node
ls -l /opt/DM/data
# ssh sveseli@dmstorage: add and start experiment e1
source /opt/DM/etc/dm.setup.sh
dm-add-experiment --name e1 --type-id 1
dm-start-experiment --name e1
# note that experiment directory permissions are restricted
ls -l /opt/DM/data/ESAF
ls -l /opt/DM/data/ESAF/e1/
# ssh dm@dmdaq: source setup file, show test data
ls -lR /opt/DM/experiments/e1
cat /opt/DM/experiments/e1/file1
# dm@dmdaq: upload data for experiment e1
dm-upload --experiment e1 --data-directory /opt/DM/experiments/e1
# dm@dmstorage: check experiment storage directory content
# note permissions, ownership
ls -l /opt/DM/data/ESAF/e1/2015/07/09/
# SCENARIO 2: UPLOAD + METADATA CATALOG
# sveseli@dmstorage: get metadata for experiment files from catalogging service
dm-get-experiment-files --experiment e1
dm-get-experiment-file --experiment e1 --file file2 --display-keys=__all__
# dm@dmdaq: upload data for experiment e1, this time specify extra keys
dm-upload --experiment e1 --data-directory /opt/DM/experiments/e1 ownerUser:JohnC ownerGroup:APSU memo1:ApprovedByNDA memo2:DislikedByGD
# sveseli@dmstorage: get metadata for file 2 again
# sveseli@dmstorage: show metadata updates
dm-update-experiment-file --experiment e1 --file file3 quality:A --display-keys=id,fileName,quality
# sveseli@dmstorage: show metadata search
dm-get-experiment-files --experiment e1 quality:A
dm-get-experiment-files --experiment e1 storageFilePath:2015
# SCENARIO 3: UPLOAD + METADATA CATALOG + SDDS PARAMETERS
# sveseli@dmstorage: add and start experiment mm1
dm-add-experiment --name mm1 --type-id 1
dm-start-experiment --name mm1
# dm@dmdaq: upload data for experiment mm1, and request SDDS parameter
# processing
ls -lR /opt/DM/experiments/mm1
dm-upload --experiment mm1 --data-directory /opt/DM/experiments/mm1 ownerUser:JohnC ownerGroup:APSU processSddsParameters:True
# sveseli@dmstorage: get mm1 files, observe SDDS parameters
dm-get-experiment-files --experiment mm1
dm-get-experiment-files --experiment mm1 --display-keys=__all__ --display-format=dict
# dm@dmstorage: compare with sddsprintout (permissions do not allow sveseli
# account to access file)
export PATH=$PATH:/opt/epics/extensions/bin/linux-x86_64/
sddsprintout -parameters /opt/DM/data/ESAF/mm1/hallProbeScan-M1Proto-000000072-0009-000000.edf
# SCENARIO 4: UPLOAD + METADATA CATALOG + SDDS PARAMETERS + SCRIPT PROCESSING
# dm@dmstorage: show processing script
cat /opt/DM/processing/find_sdds_row_count.sh
/opt/DM/processing/find_sdds_row_count.sh /opt/DM/data/ESAF/mm1/hallProbeScan-M1Proto-000000072-0009-000000.edf
# sveseli@dmstorage: get mm1 files, note no key processingScriptOutput
dm-get-experiment-files --experiment mm1 --display-keys=fileName,processingScriptOutput
# dm@dmdaq: upload data for experiment mm1, request SDDS parameter
# processing, specify processing script
dm-upload --experiment mm1 --data-directory /opt/DM/experiments/mm1 processSddsParameters:True processingScript:/opt/DM/processing/find_sdds_row_count.sh
# sveseli@dmstorage: get mm1 files, note present key processingScriptOutput
# SCENARIO 5: UPLOAD + METADATA CATALOG + SDDS PARAMETERS + HPC PROCESSING
more /opt/DM/processing/sge_sdds_analysis.sh
# dm@dmstorage: show no png files in experiment directory
ls -l /opt/DM/data/ESAF/mm1/*.png
# dm@dmhpc: show empty home directory
cd
ls -l
# dm@dmhpc: show qstat
source /opt/sge/default/common/settings.sh
qstat -f
watch -d 'qstat -f'
# sveseli@dmstorage: get mm1 files, note only 1 file
# processing, specify SGE processing script
dm-upload --experiment mm1 --data-directory /opt/DM/experiments/mm1 processSddsParameters:True sgeJobScript:/opt/DM/processing/sge_sdds_analysis.sh
# sveseli@dmstorage: get mm1 files, note 2 files
# sveseli@dmstorage: get mm1 .png files, note parentFile key
dm-get-experiment-files --experiment mm1 fileName:.png --display-keys=__all__
# dm@dmhpc: show SGE output in home directory
ls -l
# dm@dmstorage: open processed file
xdg-open /opt/DM/data/ESAF/mm1/hallProbeScan-M1Proto-000000072-0009-000000.edf.png
# SCENARIO 6: DAQ + METADATA CATALOG + SDDS PARAMETERS + HPC PROCESSING
# sveseli@dmstorage: add and start experiment mm2
dm-add-experiment --name mm2 --type-id 1
dm-start-experiment --name mm2
# sveseli@dmstorage: get mm2 files, note no files
dm-get-experiment-files --experiment mm2
ls -l /opt/DM/data/ESAF/mm2/*.png
# dm@dmstorage: tail log file to observe processing
tail -f /opt/DM/var/log/dm.ds-web-service.log
# dm@dmdaq: start DAQ for experiment mm2, request SDDS parameter
rm -rf /tmp/data/mm2
mkdir -p /tmp/data/mm2
dm-start-daq --experiment mm2 --data-directory /tmp/data/mm2 processSddsParameters:True sgeJobScript:/opt/DM/processing/sge_sdds_analysis.sh
watch -d 'qstat -f'
# dm@dmdaq: copy experiment mm2 files into observed directory, watch qstat
ls -l /opt/DM/experiments/mm2/
cp /opt/DM/experiments/mm2/* /tmp/data/mm2/ && sleep 5 && touch /tmp/data/mm2/* &
tail -f /opt/DM/var/log/dm.daq-web-service.log
# sveseli@dmstorage: get mm2 files, note original + processed files
# dm@dmstorage: show png files in experiment directory
# dm@dmdaq: stop DAQ for experiment mm2
dm-stop-daq --experiment mm2
# SCENARIO 7: DATASET DEFINITION
# sveseli@dmstorage: add metadata for couple of experiment e2 files
# with different keys
dm-add-experiment-file --experiment e2 --file x1 status:good
dm-add-experiment-file --experiment e2 --file y1 status:bad
dm-get-experiment-files --experiment e2 --display-keys=fileName,status
# sveseli@dmstorage: add dataset metadata
dm-add-experiment-dataset --experiment e2 --dataset d1 status:g.*
# sveseli@dmstorage: get dataset files, note only one file matches
dm-get-experiment-dataset-files --experiment e2 --dataset d1
# sveseli@dmstorage: add metadata for anothare e2 file that
# should match dataset constraint
dm-add-experiment-file --experiment e2 --file x2 status:great
# sveseli@dmstorage: get dataset files, note two files match
# Demo environment consists of three linux VMs:
# - data acquisition (DAQ), data storage (DS), sge cluster (HPC) nodes
# - CentOS 6.6, 64-bit
# - no shared storage
# - DS node runs PostgreSQL database server, Web Portal, DS Web Service,
# CAT Web Service, MongoDB server
# - DAQ node runs DAQ Web Service
# - HPC node runs SGE cluster
# Machine Preparation
# install dependencies (all machines)
yum install -y gcc libgcc expect zlib-devel openssl-devel openldap-devel subversion make sed gawk autoconf automake wget readline-devel
# Download globus RPM repo and install gridftp (both machines)
# http://toolkit.globus.org/ftppub/gt6/installers/repo/globus-toolkit-repo-latest.noarch.rpm
yum install globus-gridftp
# Disable requiredtty in /etc/sudoers
# Prepare gridftp server to use sshd (dmstorage machine)
globus-gridftp-server-enable-sshftp
# create system (dm) account on both machines, configure ssh-keys and
# authorized_keys files
# create several user accounts (dmstorage machine): dmuser1, dmuser2, dmuser3
# build and install epics base and SDDS/SDDSepics extensions under
# /opt/epics (dmstorage machine)
# build SDDS python under /opt/epics/extensions/src/SDDS/python/
# copy sdds.py into /opt/DM/support/python/linux-x86_64/lib/python2.7/
# copy /opt/epics/extensions/src/SDDS/python/O.linux-x86_64/sddsdatamodule.so
# into /opt/DM/support/python/linux-x86_64/lib/python2.7/lib-dynload/
# export /opt/DM to dmhpc node
# yum install nfs-util
# edit /etc/exports and add /opt/DM 192.168.100.8(rw,sync)
# exportfs -a
# restart nfs
# install sge on hpc machine, add dmstorage as submission node,
# copy /opt/sge to dmstorage
# configure /opt/DM area for software installation
mkdir -p /opt/DM
chown -R dm.dm /opt/DM
chmod 755 /opt/DM
# configure (or disable) firewall (both machines)
/etc/init.d/iptables stop
# DM Deployment: DS Machine
# Log into dmstorage node and create local DM deployment directory
# in dm user home area
cd /opt/DM
ls -l
# Checkout code as release 0.2
svn co https://subversion.xray.aps.anl.gov/DataManagement/trunk dev
# Build support area
cd dev
make support
# Source setup
source setup.sh
# Create db
make db
# Configure Web Portal
# Note:
# - this needs to be done only during the first portal deployment,
# or after portal has been unconfigured explicitly
# - this step configures DB access
# - adds initial DM system user to the DB
make configure-web-portal
# Add few users
#dm-add-user --username dmuser1 --first-name Test --last-name User1
#dm-add-user --username dmuser2 --first-name Test --last-name User2
#dm-add-user --username dmuser3 --first-name Test --last-name User3
# Deploy Web Portal
# Note:
# - deploys portal war file into glassfish
# - after this step, users can access portal at
# https://dmstorage.svdev.net:8181/dm
make deploy-web-portal
# Deploy DS Web Service
# Note:
# - generates SSL certificates and configuration files
# - after this step, DS web service is accessible at port 22236
# - log files are under DM/var/log
# - configuration files are under DM/etc
# - user setup file is DM/etc/dm.setup.sh
# - service control script is under DM/dm-0.2/etc/init.d
make deploy-ds-web-service
# Check functionality. Open second terminal and log into dmstorage node
# as user sveseli
# Source setup file to get access to DM commands
# Get user list as administrator (dm) account
dm-get-users
# DM Deployment: DAQ Machine/HPC Machine
# Log into dmdaq node and create local DM deployment directory
cd /opt/DM
ls -l
# Note the following:
# - since demo machines are identical, we could simply copy support/dm code
# from the storage node; this is not necessarily the case in general
# - support area and DM code distribution can be shared between DAQ and DS
# nodes
# - support area on the daq node is much lighter (i.e., no need
# for glassfish, etc.)
cd dev
make support-daq
# Source setup
source setup.sh
# Deploy DAQ Web Service
# Note:
# - requires storage node to be installed
# - after this step, DAQ web service is accessible at port 33336
make deploy-daq-web-service
# node
# Prepare ahead of time
# ssh sveseli@dmstorage: add experiment e1, mm2
# ssh dm@dmstorage: add few users
# Initialize demo
cd /opt/DM/dev
source setup.sh
cd /opt/DM/dev
source setup.sh
# ssh -X dm@dmhpc: start services, check NFS, check SGE
cd /opt/DM/dev
source setup.sh
qstat -f
# Check portal: https://dmstorage.svdev.net:8181/dm
# Log into portal as dm admin: https://dmstorage.svdev.net:8181/dm
# Show users
# Show experiments
# Add dmuser1 to experiment e1
# dm@dmstorage: check directory content on the storage node, should be empty
ls -l /opt/DM/data
# dm@dmstorage: check dmuser1 user, note list of groups
id dmuser1
# ssh sveseli@dmstorage: start experiment e1
# dm@dmstorage: check dmuser1 user, note user belongs to new experiment group
id dmuser1
# sveseli@dmstorage: show there are no experiment files in catalogging service
# dm@dmdaq: upload data for experiment e1, specify few arbitrary keys
# dm@dmstorage: show no files in experiment directory
watch -d 'qstat -f'
# sveseli@dmstorage: get one mm2 .edf file, note SDDS parameters in metadata
dm-get-experiment-file --experiment mm2 --file `dm-get-experiment-files --experiment mm2 --display-keys=fileName | grep -v png | head -1 | cut -f2 -d '='` --display-keys=__all__ --display-format=dict
# sveseli@dmstorage: get mm2 .png files, note parentFile key
dm-get-experiment-files --experiment mm2 fileName:.png --display-keys=fileName,parentFile --display-format=dict
# dm@dmstorage: open one processed file
xdg-open `ls -c1 /opt/DM/data/ESAF/mm2/*.png | head -1`
# exportfs -a
# restart nfs
mkdir -p /opt/DM
chmod 755 /opt/DM
cd /opt/DM
ls -l
cd dev
make support
# Source setup
source setup.sh
# Create db
make db
# Note:
# Add few users
# Deploy Web Portal
# Note:
# Note:
# as user sveseli
dm-get-users
cd /opt/DM
ls -l
# nodes
cd dev
make support-daq
# Source setup
source setup.sh
# Note:
# Demo environment consists of two linux VMs:
# - data acquisition (DAQ) and data storage (DS) nodes
# - DS node runs database server, Web Portal and DS Web Service
# install dependencies (both machines)
mkdir -p /opt/DM
chmod 755 /opt/DM
cd /opt/DM
ls -l
# Checkout code as release 0.1
svn co https://subversion.xray.aps.anl.gov/DataManagement/tags/20150421 dm-0.1
cd dm-0.1
make support
# Source setup
source setup.sh
# Create db
make db
# Note:
# Deploy Web Portal
# Note:
# Note:
# - service control script is under DM/dm-0.1/etc/init.d
# as user sveseli
# Attempt to get list of users as user sveseli, should result
# in authorization error
# Note:
# - every command comes with common set of options
dm-get-users -h
dm-get-users --version
dm-get-users
echo $?
# Repeat command, this time us administrator (dm) account
dm-get-users
# Repeat command, note that session with DS service has been established, so no
# more password prompts until session expires
cat ~/.dm/.ds.session.cache
dm-get-users
cd /opt/DM
ls -l
# nodes
cd dm-0.1
make support-daq
# Source setup
source setup.sh
# Note:
# DM Functionality: DAQ
# add new experiment (sveseli@dmstorage)
dm-add-experiment -h
dm-add-experiment --name exp1 --type-id 1 --description test
dm-get-experiments
dm-get-experiment --name exp1
dm-get-experiment --name exp1 --display-keys=__all__
# check directory content on the storage node (dm@dmstorage)
ls -l /opt/DM/data
# start experiment (sveseli@dmstorage)
dm-start-experiment --name exp1
ls -l /opt/DM/data
ls -l /opt/DM/data/ESAF/exp1/
# at this point we can log into the portal to see experiment that was created
# observe that start time is entered correctly
# in the first terminal on the daq node, tail log file (dm@dmdaq)
# open second terminal for daq node, login as system (dm) user
# source setup file (dm@dmdaq)
cat /opt/DM/etc/dm.setup.sh
# prepare DAQ directory for this experiment (dm@dmdaq)
mkdir -p /tmp/data/exp1
# start DAQ (dm@dmdaq)
dm-start-daq -h
dm-start-daq --experiment exp1 --data-directory /tmp/data/exp1
# create test file in the DAQ directory (daq node)
# observe log file entries, point out file transfer
touch /tmp/data/exp1/file1
echo "Hello there, data management is here" > /tmp/data/exp1/file1
# file1 should be transferred
# stop DAQ (dm@dmdaq)
dm-stop-daq -h
dm-stop-daq --experiment exp1
# DM Functionality: Upload
# prepare data directory we want to upload (dm@dmdaq)
mkdir -p /tmp/data/exp1/2015/04/21
echo "this is file 2" > /tmp/data/exp1/2015/04/21/file2
echo "this is file 3" > /tmp/data/exp1/2015/04/21/file3
# upload data (dm@dmdaq)
dm-upload -h
dm-upload --experiment exp1 --data-directory /tmp/data/exp1
ls -l /opt/DM/data/ESAF/exp1/2015/04/21/
cat /opt/DM/data/ESAF/exp1/2015/04/21/file3
# stop experiment (sveseli@dmstorage)
dm-stop-experiment --name exp1
# at this point we can log into the portal to see modified experiment
# observe that end time is entered correctly
mkdir -p /opt/DM
chmod 755 /opt/DM
cd /opt/DM
ls -l
svn co https://subversion.xray.aps.anl.gov/DataManagement/tags/20150630 dm-0.2
cd dm-0.2
make support
# Source setup
source setup.sh
# Create db
make db
# Note:
# The above step used two new utilities that go directly to the db:
dm-add-user -h
dm-add-user-system-role -h
# Add few users
# Deploy Web Portal
# Note:
# Show no sudo functionality for DM account
sudo -l
# Note:
# Show sudo functionality for DM account that enables group/permission
# management
sudo -l
# as user sveseli
dm-get-users
cd /opt/DM
ls -l
# nodes
cd dm-0.2
make support-daq
# Source setup
source setup.sh
# Note:
# add new experiment and couple of users (sveseli@dmstorage)
dm-add-user-experiment-role --username dmuser1 --experiment exp1 --role=User
dm-add-user-experiment-role --username dmuser2 --experiment exp1 --role=User
# Note that dmuser1 and 2 are on the list of experiment users
dm-get-experiments
ls -l /opt/DM/data
# Show that unix account corresponding to dmuser1 has no special groups
# associated with it
id dmuser1
# Show there is no exp1 unix group
grep exp1 /etc/group
# Show there is now exp1 unix group
# Check experiment user groups: only 1 and 2 should have new group assigned
# to them
id dmuser1
id dmuser2
id dmuser3
# in the first terminal on the storage node, tail log file (dm@dmdstorage)
# note permissions
# as root@dmstorage, su into dmuser1 account and try to read data
# should work
cat /opt/DM/data/ESAF/exp1/file1
# as root@dmstorage, su into dmuser3 account and try to read data
# should fail
# Demonstrate retries: show config file
vi /opt/DM/etc/dm.daq-web-service.conf
# As root@dmdaq, temporarily move rsync
mv /usr/bin/rsync /usr/bin/rsync.orig
# upload new data (dm@dmdaq), observe how transfer fails
echo "Hello there, data management is here again" > /tmp/data/exp1/file1
# As root@dmdaq, restore rsync, observe how transfer succeeds
mv /usr/bin/rsync.orig /usr/bin/rsync
# Demonstrate gridftp plugin
# Edit config file as dm@dmdaq, comment out rsync plugin, uncomment gridftp
# plugin; restart service
./etc/init.d/dm-daq-web-service restart
# upload new data (dm@dmdaq), observe how transfer succeeds
echo "Hello there, data management is here yet again" > /tmp/data/exp1/file1
Document can now be found [here](https://git.aps.anl.gov/DM/dm-docs/-/wikis/DM/HowTos/Getting-Started) on the [DM Wiki](https://git.aps.anl.gov/DM/dm-docs/-/wikis/home).
Document can now be found [here](https://git.aps.anl.gov/DM/dm-docs/-/wikis/DM/HowTos/Getting-Data-From-Globus) on the [DM Wiki](https://git.aps.anl.gov/DM/dm-docs/-/wikis/home).
RHEL7 Packages
make
autoconf
expect
gcc
gcc-c++
subversion
zlib-devel
openssl-devel
libffi-devel
openldap-devel
readline-devel
ncurses-devel
qt-x11
qt-postgresql
qt-devel
gtk2-devel
Globus Packages
globus-openssl-module
globus-ftp-client
globus-gsi-proxy
globus-gsi-openssl
globus-ftp-control
globus-gass-copy
globus-common-16.8
globus-gass-transfer
globus-io-11.8
globus-gss-assist
globus-gsi-cert
globus-xio-popen
globus-xio-gsi
globus-gsi-credential
globus-callout-3.15
globus-gsi-sysconfig
globus-gsi-callback
globus-xio-5.14
globus-gssapi-gsi
globus-gass-copy
globus-gsi-proxy
globus-gssapi-error
