Skip to content
Snippets Groups Projects
Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Target
  • DM/dm-docs
  • hammonds/dm-docs
  • hparraga/dm-docs
3 results
Show changes
Commits on Source (249)
File added
File added
File added
File added
Release 20140930 (09/30/2014) Release 4.0.0 (XX/YY/2021)
- Fixed issue with non-ascii characters for daq/upload CLI tools
- Fixed issue with locations that involve host/port for SFTP observer
- Fixed issue with incorrect DAQ_DIRECTORY_MAP replacements
- Added globus_group_id to the experiment table in the DM DB, and
modified CLIs, DB and web service APIs accordingly
- Implemented API and CLI support for Globus group management:
- New commands:
* get-globus-group
* list-globus-groups
* create-globus-group
* add-globus-group-memebers
* delete-globus-group-members
- Implemented first version of Web Portal UI: contains login page, and Release 3.3.2 (07/09/2020)
users/experiment type management pages =============================
- Developed project infrastructure tools: build scripts, web app configuration - Added ability to upload files from remote machines via rsync plugin and using
and deployment scripts ssh
- Added start/end time into GUP proposal object
Release 3.3.1 (05/06/2020)
- Maintenance release
Release 3.3.0 (05/04/2020)
- Change log4j version from 1.2.7 to 2.13.2. Code changes to adapt were
necessary. Changed config file from log4j.properties to log4j2.xml
- Change jar file for postgresql from 9.3-1102.jdbc41 to 42.2.8.
The underlying postgresql in support changed from 9.3 to 9.6 a while ago.
Release 3.2.2 (02/24/2020)
- Added user documentation (Getting Started guide)
Release 3.2.1 (01/15/2020)
- DM GUI Changes:
- Reworked configuration options for DAQs and uploads; those now support
including/excluding file extensions
- Fixed bug that was preventing using configuration options and additional
keywords at the same time
Release 3.2.0 (11/05/2019)
- Implemented ability to include or exclude file extensions for uploads and DAQs
- New API Options for starting DAQ/Upload
* includeFileExtensions
* excludeFileExtensions
- New CLI Options for starting DAQ/Upload
* include-extensions
* exclude-extensions
Release 3.1.0 (10/25/2019)
- Added new ESAF interfaces for support of extended data retrieval
- Enabled URL scheme for transfer plugin configuration; this allows
multiple gridftp hosts per deployment
- Updated support software to allow offsite installation
- DM GUI changes:
- Add settings page
- Allow user to specify refresh rates per module.
- Fixed protocol parsing bug
Release 3.0.1 (08/09/2019)
- Fixed issue with unchecked additions to metadata catalog
- Updated support software:
- OpenJDK (replaces Oracle JDK)
- Payara (replaces Glassfish)
- Added 12IDB utilities
Release 3.0.0 (07/26/2019)
- Added python web service API for downloading files
- Updated DB schema for experiment data archival support
- Web Portal changes:
- Added storage views
- Added connection between station and experiment types
- Updated experiment views with storage and root path fields
Release 2.6.0 (07/15/2019)
- Moved code repo to gitlab
- Updated release/upgrade utilities
Release 2.5.0 (06/23/2019)
- Added pprint (pretty-print) option to display format for all commands
- Added support for repeated commands via repeatPeriod/repeatUntil/maxRepeats
keys in workflow definitions
- Added skip/limit options to list-processing-jobs
- Implemented ability to stop processing jobs
- New command:
* stop-processing-job
- Enhanced support for processing multiple files with a given workflow
- New command:
* process-files
- Updated workflow API documentation
- DM Station GUI fixes/enhancements:
- Fixed issue with modifying user list before saving experiment
Release 2.4.0 (05/20/2019)
- Added system LDAP utilities for verifying and creating groups
- Added support for retrieving single processing job stage via the --stage
option for the get-processing-job command
- Prevented core files from being uploaded
- Prevented creation of experiment names with spaces
- Fixed file limit problem in compression utilities
- Fixed issue with experiment user list modification
- Added tab for monitoring processing jobs
- Restored workflow tab
Release 2.3.0 (04/15/2019)
- Updated CDB plugin for the latest CDB API changes
- Expanded support for HTML-formatted output
- Optimized amount of data transferred with file metadata listing
- Implemented limit on number of files that can be retrieved using
a single list-experiment-files command or API call
- Added more diagnostic output to compression/decompression utilities
- Added logging and ability to use DM_CONSOLE_LOG_LEVEL environment
variable to specify logging level
- Resolved issue with undefined self key in exception hook
- Added support for single file upload
- Added support for experiment root path
- Added warning dialog for experiment updates
- Added number of tooltips
- Optimized handling of file metadata for experiments with large
number of files
- Added support for pagination while fetching full list of files
- Implemented progress dialog when fetching a very large set of files
- Resolved issue with filter boxes layout not matching data table
default column sizes
Release 2.2.2 (02/11/2019)
- Updated deployment scripts
- Fixed several Python 2/3 compatibility issues
Release 2.2.1 (02/04/2019)
- Updated API documentation
- Added file compression capability
Release 2.2.0 (01/15/2019)
- Added ESAF interfaces to APS DB service
- Moved all ESAF/BSS command line utilities to APS DB service
- New command:
* list-beamlines
- Converted software to Python 3, but retained Python 2 compatibility
- Introduced support for API pip and conda packages
- Added support for a single file upload via the --file-path option to
upload commands
- Added support for arbitrary experiment path under the ${DM_STATION_NAME}
directory via the --root-path option to the following commands:
* add-experiment
* update-experiment
* ${DM_STATION_NAME}-daq
* ${DM_STATION_NAME}-upload
Note that if this option is not used, experiment will be located under
the experiment type folder, as before.
Release 2.1.0 (12/31/2018)
- Added estimated completion time to upload monitoring
- Introduced additional enhancements for cataloging plugin that shorten
uploads of large datasets
- Developed initial image receiver service and utilities that can accept
Area Detector NTNDArray frames and save them into files; currently
supported formats are SDDS, JSON, HDF5, and JPEG.
- New commands:
* start-image-receiver
* stop-image-receiver
- Added new APS DB service for accessing beamline scheduling system
Release 2.0.0 (10/15/2018)
- Modified DM DB to support arbitrary experiment root paths
Release 1.9.3 (09/15/2018)
- Added generic script processing plugin for DAQ service
- Parallelized cataloging plugin; this significantly increased performance
for uploads using directory mode
Release 1.9.2 (05/15/2018)
- Added support for compressing and decompressing files
- New commands:
* compress-files
* decompress-files
- Added support for deleting files
- New commands:
* delete-file
* delete-files
- Modified stat-file utility, which now requires explicit --md5sum flag to
retrieve checksum
- Added new --path-pattern option to the list-files command
- Added initial GUI test suite
- Added right-click copying functionality
- Fixed issue with trailing comma for DAQ/upload parameters
- Fixed CPU usage bug
- Fixed incorrect handling of user selections
- Fixed focus policy for several buttons
Release 1.9.1 (03/30/2018)
- Added support for command output in html format
- Added support for requesting only subset of keys for list of processing jobs
- Resolved issues with symbolic links for uploading directories and files
via rsync
- Fixed DAQ mode issue with double counting of observed files under certain
circumstances
- Fixed problem with cataloging of HDF5 files that contain non-ascii metadata
- Fixed issue with user permissions when creating new experiments
- Fixed upload configuration issue
- Fixed caching issues for experiment file metadata and users
- Added live metadata browsing while files load in background
- Added sorting for user table
- Added ability to copy table information to clipboard
- Improved selection behavior on tables
Release 1.9.0 (01/31/2018)
- Added support for retrieving file metadata for a given experiment in
batches; list-experiment-files get --skip and --limit options
- Simplified workflow and processing job management by allowing DM session user
to be used as default workflow and/or processing job owner
- Modified commands:
* list-workflows
* get-workflow
* delete-workflow
* start-processing-job
* list-processing-jobs
- Added support for DM_DATA_DIRECTORY_MAP environment variable; this allows
browsing data locally, while moving data using GridFTP third
party transfers
- Enhanced support for viewing large file metadata collections
Release 1.8.0 (12/15/2017)
- Enhanced algorithm for processing of existing files; this resolved issues
with multiple simultaneous DAQs involving large number of pre-existing
files that need to be processed
- Added support for retrieving experiment dataset statistics:
- New command:
* get-file-collection-stats
- Added support for output variables in workflow definitions
- Added generic HDF5 file metadata reader
- Developed DAQ/PROC service integration via new DAQ plugin; this enables
development and deployment of fully automated data acquisition/processing
pipelines based on user-defined workflows
- Modified commands (all get --workflow-name, --workflow-owner,
--workflow-job-owner and --workflow-args options):
* start-daq
* upload
- Added HTTPS support for accessing file metadata catalog via Mongo Express
- Added support for viewing experiment file metadata and file collection
statistics
- Added support for DM_BEAMLINE_MANAGERS environment variable
- Improved dialogs for DAQ/upload configuration options
Release 1.7.0 (11/01/2017)
- Added integration with ESAF DB
- Added new output formating option "--display-format=key-per-line" that is
common to all commands
- Introduced service monitoring infrastructure, which enabled deployment of
Nagios-based system monitoring
- New commands:
* get-service-status
* clear-service-status
Release 1.6.0 (10/07/2017)
- Added integration with APS ESAF DB via new APIs and CLIs
- New commands:
* list-esafs: list sector ESAFs by year
* get-esafs: retrieve ESAF by id
- Modified commands (new ESAF id option for setting experiment users)
- Enhanced DAQ processing framework with introduction of meta
classes for plugins and supporting utilities; this enables using
different processing chain depending on data location, or other
distinguishing criteria
- Added timer for automatic refresh of DAQ/upload status screens
- Split configuration options for DAQs/uploads
- Fixed issue with duplicate proposal users
- Used current date as default for experiment start/end dates
Release 1.5.0 (08/04/2017)
- Added DS interface and Java API for downloading files
- Added APIs and CLIs to clear (force service to forget) DAQs and uploads
- New commands:
* clear-daq
* clear-upload
- Introduced APSU-related enhancements:
- Processing for SDDS metadata in MongoDB cataloging plugin
- Component Database processing plugin
- Fixed issue with DM_BEAMLINE_NAME not set
- Fixed issues with buttons that require previous item selection
- Added start date to list of DAQs and uploads
- Added ability to remove completed DAQs or uploads from the top-level list
Release 1.4.0 (07/20/2017)
- Introduced DM Station GUI (accessed via dm-station-gui command)
- Introduced automated system test framework for DM stations
- Added --process-existing option to start-daq and <station>-daq
commands; this will cause upload of existing files when starting DAQs
Release 1.3.0 (05/10/2017)
- Added APIs and CLIs to update experiment attributes and metadata
catalog, as well as to delete experiments
- New commands:
* update-experiment
* update-experiment-files
* get-async-update-status
* delete-experiment
Release 1.2.0 (04/18/2017)
- Modified scheduling algorithm for DAQs/uploads to simplify status monitoring
Release 1.1.0 (03/10/2017)
- Introduced integration with Beamline Scheduling System:
- New commands:
* list-runs
* list-proposals
* get-proposal
- Added the following options to the add-experiment command:
--proposal-id: automatically add to experiment all
users associated with a given beamline proposal
--run: look for beamline proposal in a given run (current run is the
default)
--users: comma specified list of usernames to be added to experiment
as users
- Added the following options for managing DAQs:
--duration: DAQ will be stopped automatically after given
number of days or hours
--dest-directory: files will be uploaded into
a specific directory relative to experiment root path
--upload-data-directory-on-exit: when DAQ finishes, upload of the given
data directory will be executed automatically
--upload-dest-directory-on-exit: specifies destination directory for
upload after DAQ completes
- Added the following options for managing uploads:
- Introduced framework for beamline-specific tools; added
beamline-specific commands that combine adding new experiment with running
DAQs or uploads: dm-${DM_STATION_NAME}-daq and dm-${DM_STATION_NAME}-upload
- Introduced sphinx as python API documentation framework
- Resolved possible timeout issue when starting DAQ or directory upload
with a directory containing large number of files
- Simplified data directory command line option for beamlines that use
gridftp (via DM_DATA_DIRECTORY_MAP environment variable)
Release 1.0.0 (01/31/2017)
- Introduced concept of experiment station and redesigned authorization
mechanisms to allow beamline managers to manage their stations; all
APIs and CLIs now conform to the new authorization scheme
- Modified get-experiments utility to allow retrieving list of experiments
for a given station
- Cleaned up web portal by removing unused views, and enabled station
management functionality
- GPFS DDN (extrepid) has replaced xstor as the main APS storage
- CLI changes:
- add-experiment command requires station name (can be set from env.
variable); experiment type can be specified using type name
- get-experiments command requires station name for beamline managers (can
be set from env. variable)
- start-experiment command is now optional
Release 0.9.6 (11/01/2016)
- Resolved issue with incorrect accounting of processing errors for DAQs
- Improved DAQ processing algorithm to avoid resource starvation between
simultaneous DAQs and uploads
- Enhanced monitoring status information for both DAQs and uploads
Release 0.9.5 (10/14/2016)
- Introduced new framework and utilities for synchronizing users with
APS DB
- Resolved several issues with special characters in file names for
gridftp transfer plugin
Release 0.9.4 (05/27/2016)
- Added SFTP file system observer agent
- Enhanced MongoDB plugin with file md5 sum calculation
Release 0.9.3 (05/06/2016)
- Developed processing for HDF5 metadata in MongoDB cataloging plugin
- Modified catalog API and service interfaces to use file collections on
a per-experiment basis
Release 0.9.2 (04/29/2016)
- Resolved issue with upload command for directories containing large
number of files
- Implemented enhanced upload processing algorithm to avoid resource
starvation between simultaneous DAQs and uploads
- Added new polling file system observer agent as option for monitoring
directories
- Reworked catalog API and corresponding MongoDB interfaces to use unique
experiment file paths, rather than file names
Release 0.9.1 (03/11/2016)
- Added dm-list-daqs and dm-list-uploads commands
- Resolved issue with newly created directories treated as files for
real-time data acquisitions
Release 0.9.0 (02/25/2016)
- Developed directory processing mode for uploads; in this mode file transfer
plugins transfer entire directories as opposed to individual files
- Added dm-get-processing-plugins command
- Resolved working directory issue that may occur with simutaneous uploads
Release 0.8.0 (01/26/2016)
- Enhanced upload/daq performance and functionality (hidden files are not
processed; for uploads system can detect files that had been processed
already; improved handling and reporting of processing errors)
- Source file checksum is calculated for rsync/gridftp plugins by default
- Added dm-stop-upload command
- Resolved globus online user authorization delay issue
Release 0.7.0 (12/08/2015)
- Introduced framework and user interfaces for tracking progress of file
uploads and data acquisitions in DAQ service
- Added ability to monitor multiple directories for the same experiment
simultaneously (required changes to DAQ service REST interfaces)
- Enhanced start/stop DAQ and upload commands to use DM_FILE_SERVER_URL
- Added user interfaces and utilities that enable experiment data download
from machines that have SSH access to the storage host
Release 0.6.0 (11/06/2015)
- Added file system observer agent interface for DAQ service
- Implemented FTP file system observer for DAQ service
- Added interfaces for deleting user experiment role in DS service
- Introduced java REST API framework, and specific experiment DS service API
- Web Portal notifies DS service about experiment user modifications
Release 0.5.0 (10/08/2015)
- Implemented Single Sign-On solution for backend services
- Enabled user authentication via login file
- Added file stat (with checksum) interface in DS web service
- After adding user role to experiment via command line, user is also
added to experiment group (if one exists)
- Added rsync file transfer plugin with checksum and delete
Release 0.4.0 (09/21/2015)
- Number of minor modifications made in preparation for test deployment at
beamlines
Release 0.3.0 (07/22/2015)
- Developed initial version of Catalogging Web Service based on MongoDB
- Developed sample processing plugins: file metadata catalog, SDDS processing,
SGE job submission
Release 0.2.0 (06/30/2015)
- Implemented storage permission management and user group management
- Developed common file processing service plugin framework
Release 0.1.0 (04/21/2015)
- Functional web portal (user, experiment, and policy pages)
- Developed web service and its API/CLI frameworks
- Developed initial version of Data Storage Web Service
- Developed initial version of Data Acquisition Web Service;
- DAQ service can monitor file system on a detector node and subsequently
transfer data to storage
File added
"1-BM-B,C"
"1-ID-B,C,E"
"2-BM-A,B"
"2-ID-D"
"2-ID-E"
"3-ID-B,C,D"
"4-ID-C"
"4-ID-D"
"5-BM-C"
"5-BM-D"
"5-ID-B,C,D"
"6-BM-A,B"
"6-ID-B,C"
"6-ID-D"
"7-BM-B"
"7-ID-B,C,D"
"8-BM-B"
"8-ID-E"
"8-ID-I"
"9-BM-B,C"
"9-ID-B,C"
"10-BM-A,B"
"10-ID-B"
"11-BM-B"
"11-ID-B"
"11-ID-C"
"11-ID-D"
"12-BM-B"
"12-ID-B"
"12-ID-C,D"
"13-BM-C"
"13-BM-D"
"13-ID-C,D"
"13-ID-E"
"14-BM-C"
"14-ID-B"
"15-ID-B,C,D"
"16-BM-B"
"16-BM-D"
"16-ID-B"
"16-ID-D"
"17-BM-B"
"17-ID-B"
"18-ID-D"
"19-BM-D"
"19-ID-D"
"20-BM-B"
"20-ID-B,C"
"21-ID-D"
"21-ID-E"
"21-ID-F"
"21-ID-G"
"22-BM-D"
"22-ID-D"
"23-BM-B"
"23-ID-B"
"23-ID-D"
"24-ID-C"
"24-ID-E"
"26-ID-C"
"27-ID-B"
"28-ID-B"
"28-ID-C"
"29-ID-C,D"
"30-ID-B,C"
"31-ID-D"
"32-ID-B,C"
"33-BM-C"
"33-ID-D,E"
"34-ID-C"
"34-ID-E"
"35-ID-B,C,D,E"
- DS service
- runs on extrepid
- DAQ service
- APSU station, runs on ctlsdaqsrv2
- Catalog service
- Processing (Workflow) service
- can run workflows for each file, or for set of files, in real-time
- RT workflow args can be set via PV
- DAQ needs to send burst number (e.g, file 3/10)
- can always request workflow processing on a set of files (post processing)
- need portal that will be able to submit processing job
- need to be able to keep track of processing jobs and their results
- DM/CDB integration plugin
- triggered via CDB:<qrId> keyword
- adds DM-document property, will have metadata catalog URL,
file download URL, metadata key/value pairs as needed
- must be able to associate multiple qrID's
- CDB Document domain
- CDB/DM integration plugin: needs to be able to click on the file to see the
metadata, or to download the file
- DM/SDDS plugin
- triggered by ".sdds"
- reads parameters, converts them to metadata
- Use Case: StudiesSession-20170422
- From CDB perspective StudiesSession-20170422 is an item in the
Documents Domain
- From DM perspective, StudiesSession-20170422 is an experiment on an APSU
station
- When collecting DAQ data, DM will automatically asign all files to be
part of the StudiesSession-20170422 experiment
- DM/CDB plugin will add DataFile property to StudiesSession-20170422 for
each file
- CDB/DM file property handler will be able to display DM metadata (URL link)
and download file; later, it may be be able to submit processing job
to DM processing service
# Demo environment consists of two linux VMs:
# - data acquisition (DAQ) and data storage (DS) nodes
# - CentOS 6.6, 64-bit
# - no shared storage
# - DS node runs database server, Web Portal and DS Web Service
# - DAQ node runs DAQ Web Service
# Machine Preparation
# install dependencies (both machines)
yum install -y gcc libgcc expect zlib-devel openssl-devel openldap-devel subversion make sed gawk autoconf automake wget readline-devel
# create system (dm) account on both machines, configure ssh-keys and
# authorized_keys files
# configure /opt/DM area for software installation
mkdir -p /opt/DM
chown -R dm.dm /opt/DM
chmod 755 /opt/DM
# configure (or disable) firewall (both machines)
/etc/init.d/iptables stop
# DM Deployment: DS Machine
# Log into dmstorage node and create local DM deployment directory
# in dm user home area
cd /opt/DM
ls -l
# Checkout code as release 0.1
svn co https://subversion.xray.aps.anl.gov/DataManagement/tags/20150421 dm-0.1
# Build support area
cd dm-0.1
make support
# Source setup
source setup.sh
# Create db
make db
# Configure Web Portal
# Note:
# - this needs to be done only during the first portal deployment,
# or after portal has been unconfigured explicitly
# - this step configures DB access
make configure-web-portal
# Deploy Web Portal
# Note:
# - deploys portal war file into glassfish
# - after this step, users can access portal at
# https://dmstorage.svdev.net:8181/dm
make deploy-web-portal
# Deploy DS Web Service
# Note:
# - generates SSL certificates and configuration files
# - after this step, DS web service is accessible at port 22236
# - log files are under DM/var/log
# - configuration files are under DM/etc
# - user setup file is DM/etc/dm.setup.sh
# - service control script is under DM/dm-0.1/etc/init.d
make deploy-ds-web-service
# Check functionality. Open second terminal and log into dmstorage node
# as user sveseli
# Source setup file to get access to DM commands
source /opt/DM/etc/dm.setup.sh
# Attempt to get list of users as user sveseli, should result
# in authorization error
# Note:
# - every command comes with common set of options
dm-get-users -h
dm-get-users --version
dm-get-users
echo $?
# Repeat command, this time us administrator (dm) account
dm-get-users
# Repeat command, note that session with DS service has been established, so no
# more password prompts until session expires
cat ~/.dm/.ds.session.cache
dm-get-users
# DM Deployment: DAQ Machine
# Log into dmdaq node and create local DM deployment directory
cd /opt/DM
ls -l
# Note the following:
# - since demo machines are identical, we could simply copy support/dm code
# from the storage node; this is not necessarily the case in general
# - support area and DM code distribution can be shared between DAQ and DS
# nodes
# - support area on the daq node is much lighter (i.e., no need
# for glassfish, etc.)
cd dm-0.1
make support-daq
# Source setup
source setup.sh
# Deploy DAQ Web Service
# Note:
# - requires storage node to be installed
# - after this step, DAQ web service is accessible at port 33336
make deploy-daq-web-service
# DM Functionality: DAQ
# add new experiment (sveseli@dmstorage)
dm-add-experiment -h
dm-add-experiment --name exp1 --type-id 1 --description test
dm-get-experiments
dm-get-experiment --name exp1
dm-get-experiment --name exp1 --display-keys=__all__
# check directory content on the storage node (dm@dmstorage)
ls -l /opt/DM/data
# start experiment (sveseli@dmstorage)
dm-start-experiment --name exp1
ls -l /opt/DM/data
ls -l /opt/DM/data/ESAF
ls -l /opt/DM/data/ESAF/exp1/
# at this point we can log into the portal to see experiment that was created
# observe that start time is entered correctly
# in the first terminal on the daq node, tail log file (dm@dmdaq)
tail -f /opt/DM/var/log/dm.daq-web-service.log
# open second terminal for daq node, login as system (dm) user
# source setup file (dm@dmdaq)
cat /opt/DM/etc/dm.setup.sh
# prepare DAQ directory for this experiment (dm@dmdaq)
mkdir -p /tmp/data/exp1
# start DAQ (dm@dmdaq)
dm-start-daq -h
dm-start-daq --experiment exp1 --data-directory /tmp/data/exp1
# create test file in the DAQ directory (daq node)
# observe log file entries, point out file transfer
touch /tmp/data/exp1/file1
echo "Hello there, data management is here" > /tmp/data/exp1/file1
# file1 should be transferred
# stop DAQ (dm@dmdaq)
dm-stop-daq -h
dm-stop-daq --experiment exp1
# DM Functionality: Upload
# prepare data directory we want to upload (dm@dmdaq)
mkdir -p /tmp/data/exp1/2015/04/21
echo "this is file 2" > /tmp/data/exp1/2015/04/21/file2
echo "this is file 3" > /tmp/data/exp1/2015/04/21/file3
# upload data (dm@dmdaq)
dm-upload -h
dm-upload --experiment exp1 --data-directory /tmp/data/exp1
ls -l /opt/DM/data/ESAF/exp1/2015/04/21/
cat /opt/DM/data/ESAF/exp1/2015/04/21/file3
# stop experiment (sveseli@dmstorage)
dm-stop-experiment --name exp1
# at this point we can log into the portal to see modified experiment
# observe that end time is entered correctly
Document can now be found [here](https://git.aps.anl.gov/DM/dm-docs/-/wikis/DM/HowTos/Getting-Started) on the [DM Wiki](https://git.aps.anl.gov/DM/dm-docs/-/wikis/home).
Document can now be found [here](https://git.aps.anl.gov/DM/dm-docs/-/wikis/DM/HowTos/Getting-Data-From-Globus) on the [DM Wiki](https://git.aps.anl.gov/DM/dm-docs/-/wikis/home).
cd /local/DmSystem/dm
source setup.sh
make deploy-cat-web-service
cd /local/DmSystem/support
./bin/install_node.sh
cd /local/DmSystem/support/node/linux-x86_64/bin/node_modules/mongo-express/
cp config.default.js config.js
vi config.js
export PATH=/local/DmSystem/support/node/linux-x86_64/bin:$PATH
../forever/bin/forever start app.js
../forever/bin/forever list
RHEL7 Packages
make
autoconf
expect
gcc
gcc-c++
subversion
zlib-devel
openssl-devel
libffi-devel
openldap-devel
readline-devel
ncurses-devel
qt-x11
qt-postgresql
qt-devel
gtk2-devel
Globus Packages
globus-openssl-module
globus-ftp-client
globus-gsi-proxy
globus-gsi-openssl
globus-ftp-control
globus-gass-copy
globus-common-16.8
globus-gass-transfer
globus-io-11.8
globus-gss-assist
globus-gsi-cert
globus-xio-popen
globus-xio-gsi
globus-gsi-credential
globus-callout-3.15
globus-gsi-sysconfig
globus-gsi-callback
globus-xio-5.14
globus-gssapi-gsi
globus-gass-copy
globus-gsi-proxy
globus-gssapi-error
