| ... | @@ -8,7 +8,7 @@ ___ |
___
___
## coming out of shutdown
## Coming out of shutdown
0) power cycle PI controllers, smarAct, SRS and blue box as needed; SRS.set_all()
1) home motors using procedure [here](https://git.aps.anl.gov/groups/29id/-/wikis/RSXS/Kappa-Diffractometer/PI-Motors)
2) check tth minimum/maximum allowed position in extended panel (PI software): after homing tth PI/dial position will be set to either of those, which will prevent it to move it in that direction
| ... | @@ -32,7 +32,7 @@ Scan_D5D() |
Scan_Slit3D_center()
## energy calibration
## Energy calibration
Good to check after a shutdown:
1) use C branch to check mirrors alignment (M0,M1,M2,GRT) and energy drift accross beamline energy range.
2) Use STO/Si/LAO sample to measure XAS and change M3R roll (coarse) and/or slit (fine) center to refine energy calibration:
| ... | @@ -43,7 +43,7 @@ Good to check after a shutdown: |
## align M3R pitch to center of rotation
## Align M3R pitch to center of rotation
1) start from the last known value for M3R pitch ie desired pixel value (typically betwen 110-115)
2) align direct beam on d4 and reset tth0:
```python
```python
| ... | @@ -81,7 +81,7 @@ note: you can do this a th=0 or th=180 (align_z0 or align_z180), depending on wh |
## determine kth offset
## Determine kth offset
If th_0 and th_180 is the motor position at specular near th=15 and th=165, respectivaley (eg th0=13.671 and th180=163.65):
```python
```python
| ... | @@ -133,7 +133,7 @@ align_z0_chi0() |
## determine kap offset
## Determine kap offset
1) compare kap scans at (th,chi,phi) = (90,0,90) and (270,0,-90):
| ... | @@ -148,7 +148,7 @@ dscankap(-4,4,0.1) |
## determine kphi and phi 0
## Determine kphi and phi 0
<ol>
<ol>
<li>
<li>
