... | @@ -10,7 +10,7 @@ ___ |
## Coming out of shutdown
0) power cycle PI controllers, smarAct, SRS and blue box as needed; SRS.set_all()
1) If Kappa IOC is not running, connected to junebug, type crontab -l and copy portion of command to start IOC
1) If Kappa IOC is not running, connect to junebug as 29id, type crontab -l, and copy portion of command to start IOC
2) home motors using procedure [here for PI](https://git.aps.anl.gov/groups/29id/-/wikis/RSXS/Kappa-Diffractometer/PI-Motors) and [here for SmarAct](https://git.aps.anl.gov/groups/29id/-/wikis/RSXS/Kappa-Diffractometer/SmarAct)
3) check tth minimum/maximum allowed position in extended panel (PI software): after homing tth PI/dial position will be set to either of those, which will prevent it to move it in that direction
4) sync EPICS values:
