| ... | ... | @@ -11,14 +11,14 @@ To home tth from : m |
- In pop up screen, enter IP address: 164.54.118.24
- Turn current on:  => Motor On + send
- Limit switches are close to the position where d4 is in direct beam. Check soft limits allow movement over that range:
- Set limit settings to ignore normally closed for both directions:
- Set limit settings to ignore normally closed for both directions in:
- Move between the 2 limits and look for when the limit light flashes: They are about 10 degrees apart, a little after direct beam on the negative hemisphere of the chamber
- E1 = cal = limit reverse
- E2 = rm = limit forward
- Move to a value more positive than E1
- Set limit settings to normally closed for both directions
- Set limit settings to normally closed for both directions in:
- once in between the 2 limits, click ncal
- software should reset tth to 0
- reset soft limits
