... | @@ -41,9 +41,10 @@ To home tth from ![image](uploads/980f2f9c2666873734aa9fac9361a535/image.png): m |
- Set limit settings to normally closed for both directions in: ![image](uploads/22033937627b72b32825c700066dc509/image.png)
- When more positive than E1 (cal) position, click ncal to home cal in negative direction![image](uploads/e40cef0f3899e5828930152ac30811f6/image.png)
- Software should reset tth to 0 when reaches E1
- Reset soft limits to reverse = -200 and forward = -100 in: ![image](uploads/33c6c1d2a222252947b903e610567405/image.png)
- Reset soft limits to reverse = -200 and forward = 100 in: ![image](uploads/33c6c1d2a222252947b903e610567405/image.png)
- Set limit settings to ignore normally closed for both directions in: ![image](uploads/22033937627b72b32825c700066dc509/image.png)
- Close LabView
- Close LabView
- Redefine TTH=0 in epics by scanning direct beam on d4.
## How to home TTH from PI software (not recommended):
... | @@ -70,10 +71,10 @@ TTH homing procedure from the PI software (not recommended for tth, see labview |
- 3 1 1 setsw
- 3 1 1 setsw
- 1 getsw (to clear the error): should read 3 3 = upper and lower limits disabled (need to do both); ready for operation
Check your limits:
Check your limits:
Set maximum allowed position to 100 (-100 in diffractometer coordinates, "User").
- Set maximum allowed position to 100 (-100 in diffractometer coordinates, "User").
Set minimum allowed position to -210 (210 in diffractometer coordinates, "User").
- Set minimum allowed position to -210 (210 in diffractometer coordinates, "User").
___
___
