| ... | @@ -7,10 +7,10 @@ ___ |
___
___
## Homing:
# Homing:
### How to home KAP and KTH:
- Start PI software and make sure that servos are on
- #Note that if an axis will not move, check soft limits
| ... | @@ -22,7 +22,7 @@ ___ |
### How to home TTH from labview (preferred):
To home tth from : make sure the .vi is running:
| ... | @@ -46,7 +46,7 @@ To home tth from : m |
- Close LabView
- Close LabView
### How to home TTH from PI software (not recommended):
TTH homing procedure from the PI software (not recommended for tth, see labview procedure above instead):
| ... | @@ -80,22 +80,44 @@ ___ |
___
___
# Kappa motors
# Troubleshooting
## Troubleshooting
## Remote reboot:
To reboot controllers remotely (equivalent to power cycling the controller):
- Open the Demo.vi on crabby (in the windows home button: SMChydraSDemoLV2012)
- Press the "run" arrow on top left to start Labview if not already runnning
- Enter IP address on pop-up screen DLG_Connect.vi as shown below (164.54.118.9 (kap #1,kth #2) or 164.54.118.24 (tth)); set port number to 400, then press OK
- Open a terminal: click reset, then click exit
- Close software
- Wait 20s
- Reopen software
- Enter IP again: 164.54.118.9 (kap #1,kth #2) or 164.54.118.24 (tth), port 400.
- Press init for both axis (1 and 2)
WARNING: power cycle reset parameters! To make sure parameters are saved see below.
## Troubleshooting steps:
- power cycle controllers
- switch from close loop adaptive to open loop
- decrease velocity (for kth we used 1 instead of 1.5)
- increase motor current; idealy, want to keep operating current under the following values:
- increase motor current; ideally, want to keep operating current under the following values:
- in vacuum: 0.7-0.8A
- in air: 1.2A<br>
- in air: 1.2A<br>
however
however
- swap motor cable at the controller
- measure resistance of the motor: 4<span>Ω</span> between pin 1-2 & 3-4
- measure resistance of the motor (unplug cable from Hydra): 4<span>Ω</span> between pin 1-2 & 3-4
- As a last resort, break vacuum:
- is there noise? current setting can be set higher in air (see value above)
- unplug motor and move stage by hand using shaft handle (can swap handles from one stage to the other)
- compare with other stages, should be easy; if sticky point, run over it again and again until smooth
- plug back motor, run in air, then pump and run in vacuum (remember to change current setting)
## Temperature:
## Temperature:
| ... | @@ -103,33 +125,18 @@ however |
- Extra wires on kth/kap stages = thermocouple: max T =180deg ; keep T <160 deg
## Home
## Save parameters
## Save parameters
- go to terminal
- save all
## Routine rotation service:
## Remote reboot:
- motor should be moved over their entire range on a regular basis (every week) to prevent sticky point
Enter IP address on pop-up screen DLG_Connect.vi as shown below (164.54.118.9 (kap #1,kth #2) or 164.54.118.24 (tth)); port number is 400, then press OK
Close software
Wait 20s
Reopen software
## Service rotation
### Pictures:
| ... | @@ -146,21 +153,13 @@ To reboot controllers remotely (equivalent to power cycling the controller): |
# Random assortment of notes about PI motors
## Random assortment of notes about PI motors
If KTH is shaking: make sure Integral (I) coeff at stanstill =< 0.002 or lower
PI stages are running left handed in the native software.
Dial positions in epics match PI software after the following homing procedure.
KAP (417005588): Reference using negative limit, located around -44 on KAP; sets motor to 0
KTH (417005589): Reference using negative limit, located around outboard 10CF window (ie KTH ~ -40); sets motor to 0
If the softIOC (29idKappa @ Junebug) takes minutes to come online:
Stop the IOC
Stop the IOC
| ... | @@ -168,12 +167,6 @@ If the softIOC (29idKappa @ Junebug) takes minutes to come online: |
Start the IOC
Start the IOC
Email from Baehr, Joerg <J.Baehr@pi.de>, 4/8/2021
