| ... | @@ -10,7 +10,7 @@ ___ |
# Homing:
# Homing:
## How to home KAP and KTH:
- Start PI software and make sure that servos are on
- #Note that if an axis will not move, check soft limits
| ... | @@ -22,7 +22,7 @@ ___ |
## How to home TTH from labview (preferred):
To home tth from : make sure the .vi is running:
| ... | @@ -47,7 +47,7 @@ To home tth from : m |
- Redefine TTH=0 in epics by scanning direct beam on d4.
## How to home TTH from PI software (not recommended):
TTH homing procedure from the PI software (not recommended for tth, see labview procedure above instead):
| ... | @@ -70,8 +70,7 @@ TTH homing procedure from the PI software (not recommended for tth, see labview |
- 3 0 1 setsw
- 3 0 1 setsw
- 3 1 1 setsw
- 3 1 1 setsw
- 1 getsw (to clear the error): should read 3 3 = upper and lower limits disabled (need to do both); ready for operation
Check your limits:
Check your limits:
- Set maximum allowed position to 100 (-100 in diffractometer coordinates, "User").
- Set minimum allowed position to -210 (210 in diffractometer coordinates, "User").
