| ... | @@ -11,6 +11,1567 @@ https://anl.box.com/s/awyic3ykmn8twjjh7cumv259p4e0ys9g (recording to come) |
# Import functions
<font color='blue'>RSXS 101 from Padraic Shafer (ALS) can be found at:</font>
<br>
# Experiment set-up
<font color='blue'>All of the beamline functions can be found at:</font>
https://git.aps.anl.gov/rodolakis/Macros_29id/-/tree/master/
```python
%run Macros_29id/hklpy/ScanFunctions_hkl.py
fourc modes: ['bissector', 'constant_omega', 'constant_chi', 'constant_phi', 'double_diffraction', 'psi_constant']
selected mode: constant_phi
axis low_limit high_limit value fit
omega -20.0 150.0 0.0 True
chi -29.999999999999996 100.0 0.0 True
phi -180.0 180.0 0.0 True
tth 0.0 180.0 0.0 True
WARNING: wavelength set to 1.540 A = 8050.92 eV
```python
# A few custom function:
# n=scan number, 33/34 = detector number (big/small diode, respectively)
# 0.1= starting FWHM, fit function = lorz, gauss or erf (error function)
def fit_d4(n):
fit_mda(n,34,0.1,'lorz')
def fit_d3(n):
fit_mda(n,33,3,'gauss')
def fit_z(n,d=33):
fit_mda(n,d,500,'erf')
```python
Folder_Kappa('NXschool')
Current run: 2021_2
To create ftp folders & update contrab, you need to run the following as 29id:
Folder_Kappa('2021_2','NXschool',ftp=True)
Current run: 2021_2
Current run: 2021_2
MDA folder: /net/s29data/export/data_29idd/2021_2/NXschool/mda
SPEC folder: /home/beams22/29IDUSER/spec/data/2021_2/NXschool/
You will need to create folder and set up the path manually in SPEC:
cd /home/beams22/29IDUSER/spec/data/2021_2/NXschool/
newfile FileName
To start SPEC fresh: ./bin/kappa29ID -f
06/30/2021: cammented our Folder_MPA(...)
ScanIOC set to: Kappa
Save Status Kappa: Active - saveData OK
Log FileName = '20210727_log.txt' @ 29idb:userStringSeq10.STR3
To change FileName, use logname_set("newname")
REMINDER: Reset_Scan('Kappa'); Reset_CA_all(); Reset_Mono_Limits(); Sync_SmarAct_Motor(); Sync_PI_Motor(); Sync_Euler_Motor()
```python
path='/net/s29data/export/data_29idd/2021_2/NXschool/mda'
```python
Reset_Scan('Kappa'); MPA_ROI_SetAll(); Reset_Mono_Limits(); Sync_SmarAct_Motor(); Sync_PI_Motor(); Sync_Euler_Motor()
Resetting 29idKappa:scan1
Scan record reset to default.
WARNING: Detectors are set for Kappa, with X-rays and in Users mode
Kappa scalers are triggered. Counting time set to 0.1s
Checking if all detectors & positioners are connected...
All the current amplifiers have been reset; ca5 set to passive.
Mono limits have been reset.
SamrAct motors VAL homed
PI motors VAL synced to RBV
Euler motors VAL/RBV synced to physical motors
```python
Get_All(); mprint() # print current status of the beamline;
# we start at 500 eV in circular right polarization which is our default settings
ID SP : 512.80 eV ID mode : RCP
ID RBV : 505.13 eV QP mode : 100 %
Mono : 500.00 eV GRT : MEG
Mono Optics: Au_1000 - Dummy
MIR Offset : 0.3400 MIR Tx : -12.040
GRT Offset : 0.7369 GRT Tx : 131.624
GRT b2 : -7.1860e-05 GRT Density: 1200.0 l/mm
cff : 2.1007 exit arm: 20000.0 mm
tun0 : 0.0000e+00 tun1: 0.0000e+00
tun2 : 0.0000e+00 tun3: 0.0000e+00
Slit-1A = (1.92x1.8) @ (0.12,-0.13)
Slit-2B = (2.81x3.3) @ (-0.25,-0.25)
Slit-3C = 50.0 um
Slit-3D = 100.0 um @ -270.0 um
M1 @ 0.650 / -21.500 / 0.000 / 0.000 / 8.575 / 3.000
M3R @ -2.500 / -0.000 / 0.000 / -13.955 / -16.45004 / -6.000
=> In D branch
ARPES = [-1.252, -1.002, 13.75, 0.003, 0.0, 0.0]
Kappa = [-5.6, -0.1, 0.4, -0.0, 108.009, 131.813, 55.164]
x,y,z,tth,th,chi,phi = [-6.0,-0.0,0.0,-0.0,52.835,88.743,-0.01]
x,y,z,tth,kth,kap,kphi = [-6.0,-0.0,0.0,-0.0,108.01,131.81,55.16]
[-6.0, -0.0, 0.0, -0.0, 108.01, 131.81, 55.16]
# Aligning the sample
<font color='blue'>We have 3 detectors (parenthesis indicate the detector number in scans):
- <font color='blue'>D3 (#33) $\Rightarrow$ big photodiode (3 degrees angular acceptance)
- <font color='blue'>D4 (#34) $\Rightarrow$ small photodiode (0.1 angular acceptance)
- <font color='blue'>MCP (#35) $\Rightarrow$ 2D microchannel plate
<font color='blue'>The MCP is very sensitive and can be damaged when exposed to too many count, so we do the alignment using the photodiodes which have a large dynamic range. </font>
- <font color='blue'>$tth = 0$ corresponds to direct beam on the detector (defined absolutely)
- <font color='blue'>$th =$ angle between the sample surface and the beam; $th = 0$ corresponds to grazing incidence.
<font color='blue'>Since $tth = 0$ is defined by the direct beam, we have to define the $tth=0$ for each detector. This is done automatically by using the following function:</font>
```python
setdet('d3')
Detector now set to: d3
<font color='blue'>We can check our $tth=0$ by scanning the direct beam (with the sample out of the way):
```python
scantth(-5,5,0.5) # start , stop, step
Scan1: 29idKappa:m9.VAL= -5.0 / 5.0 / 0.5
Kappa_1 started at Tue 27 Jul 2021 13:49:14
Kappa_1 finished at Tue 27 Jul 2021 13:49:48
```python
plot_mda(1,33) # plot scan #1 for detector #33 (big diode)
/home/beams/29IDUSER/Documents/User_Folders/NXschool/lastfigure.png
<font color='blue'>D3 is much bigger than the beam, so a better way to verify $tth=0$ is to scan the direct beam with the small diode:
```python
detset('d4')
Detector now set to: d4
<font color='blue'>This function recalculate the current tth position for a given detector (based on the absolute offset between all 3 detectors); but it does not MOVE tth. To put D4 in direct beam, we need to move it to tth=0; then we can scan the direct beam: </font>
```python
mvtth(0)
tth = 0.001
```python
scantth(-0.25,0.25,0.025)
Scan1: 29idKappa:m9.VAL= -0.25 / 0.25 / 0.025
Kappa_3 started at Tue 27 Jul 2021 13:55:23
Kappa_3 finished at Tue 27 Jul 2021 13:55:38
```python
fit_d4(3) # fit scan #2 with a lorentzian
a0 = 120.299
Amplitude: 39158.34097137744
Center: 0.07077552359554651
FWHM: 0.15285053788234348
<font color='blue'>We move tth to the max intensity and reset tth to be 0 at this position:
```python
mvtth(0.0707)
tth = 0.071
```python
tth0_set()
Are you sure you want to reset tth0 (Y or N)? >
y
tth position reset to 0
<font color='blue'>We can check the beam is now perfectly center to 0:
```python
Kappa_5 started at Tue 27 Jul 2021 13:57:11
Kappa_5 finished at Tue 27 Jul 2021 13:57:26
```python
fit_d4(5)
a0 = 120.207
Amplitude: 39378.87271639315
Center: 0.00031304001837008534
FWHM: 0.15673500299341367
<font color='blue'>Since we know the aboslute offset between D4 and the other 2 detectors, aligning d4 is enough to align all the detectors. We can switch back to the big diode (D3) and start aligning the sample into the beam:
```python
detset('d3')
### Align z:
<font color='blue'>We can now align the sample into the beam; we start with the z-axis, which is along the sample normal. In grazing incidence (th=tth=0), by moving the sample into the beam, the center of the beam corresponds to half intensity on the detector:
```python
dscanz(-750,750,50) # dscan (start, stop step) = relative scan ( here in microns!)
Scan1: 29idKappa:m4.VAL= 1250.18 / 2750.18 / 50.0
Kappa_6 started at Tue 27 Jul 2021 14:04:37
Kappa_6 finished at Tue 27 Jul 2021 14:05:03
```python
fit_mda(6,33,500,'erf') # this can be fit with an error function
a0 = 120.216
Center: 1967.3651562707807
FWHM: 244.94053625131173
1967.3651562707807
We go to half intensity:
```python
mvz(1967)
z = 1967.004
### Align th:
<font color='blue'><p>Now we want to make sure the sample is perfectly grazing. Even if we set th to 0, each sample has its own offset with respect to the diffractometer; this depends on how the sample was mounted on the sample plate, etc.
<p>The best way to do so is to go to specular, ie use the sample as a mirror by going to $tth = 2 * th$, which works well for a thin film (can be challenging with single crystals which typically are smaller and have multiple facets). <\p>
<p>Since tth = 0 is absolutely defined by the direct beam, the reflected beam will hit the detector only if: $th + th_0 = tth / 2$, where th and tth are the actual motor positions (th$_0$ is the offset between the surface normal and the diffractometer).<\p>
<font color='blue'><p>The small diode is more accurate for this measurment:
```python
setdet('d4')
```python
uan(10,5) # move tth and th simultaneously
tth=10 th=5
```python
dscanth(-0.5,0.5,0.05) # dscan (start, stop step) = relative scan
Scanning pseudo motor 29idKappa:Euler_Theta
Scan1: 29idKappa:Euler_Theta= 2.75 / 3.75 / 0.05
Kappa_10 started at Tue 27 Jul 2021 14:13:07
Kappa_10 finished at Tue 27 Jul 2021 14:13:31
```python
fit_mda(10,34,0.1,'gauss') # fit scan #10, looking at detector #34 (=D4), FWHM ~ 0.1
a0 = 120.462
Amplitude: 17924.99343190811
Center: 3.2055383959530572
FWHM: 0.09939643617320348
3.2055383959530572
<font color='blue'>We can take smaller steps to get a better fit:
```python
dscanth(-0.25,0.25,0.02)
Scan1: 29idKappa:Euler_Theta= 2.951 / 3.451 / 0.02
Kappa_12 started at Tue 27 Jul 2021 14:16:29
Kappa_12 finished at Tue 27 Jul 2021 14:16:50
```python
fit_mda(12,34,0.1,'gauss')
a0 = 120.673
Amplitude: 17618.190739381385
Center: 3.208274111103298
FWHM: 0.09739105096421925
3.208274111103298
<font color='blue'>Which gives us $th_0$:
```python
th0=3.208-5
```python
th0
-1.7919999999999998
### Second iteration:
<font color='blue'>Since the sample was not perfectly grazing when we measured z, so we iterate:
```python
mvth(th0) # putting the sample back to grazing using the new th0 value
th = -1.795
```python
detset('d3') # change detector to big diode
```python
mvtth(0) # moving D3 back to direct beam
tth = 0.0
```python
dscanz(-750,750,50)
Scan1: 29idKappa:m4.VAL= 1216.723 / 2716.723 / 50.0
Kappa_13 started at Tue 27 Jul 2021 14:19:54
Kappa_13 finished at Tue 27 Jul 2021 14:20:20
```python
fit_z(13)
a0 = 120.091
Center: 2031.0403661654516
FWHM: 238.57571794220107
```python
mvz(2031)
z = 2030.998
<font color='blue'><p>z at $th = th_0$ is slightly different ($+ 60 \mu m$)
<font color='blue'><p>Now we iterate over th:
```python
detset('d4')
```python
uan(10,5+th0)
tth=10 th=3.208
```python
dscanth(-0.25,0.25,0.025)
Scan1: 29idKappa:Euler_Theta= 2.957 / 3.457 / 0.025
Kappa_16 started at Tue 27 Jul 2021 14:25:47
Kappa_16 finished at Tue 27 Jul 2021 14:26:06
```python
fit_d4(16)
a0 = 120.016
Amplitude: 15981.312440035206
Center: 3.1909668138089344
FWHM: 0.11077736027605263
```python
th0=3.19-5
print(th0)
-1.81
```python
mvth(3.19)
th = 3.195
<font color='blue'><p>$th _0$ is unchanged (difference is only 0.01); we can move one.
<font color='blue'><p>The next step is to check x and y. The sample is relatively big (5x3mm) so we were able to center the beam on the sample just by using a standard camera.
### Align x & y:
<font color='blue'>There are several ways to double check x and y, for example:
- <font color='blue'>go to normal incidence th=90 (ie the sample surface is perpendicular to the beam), and raster the beam in x (up/down) and y (left/right) by looking at the drain current (photoelectric effect). This can be done by taking cuts in x and y or, for small sample, by taking a 2D scan in x/y.
- <font color='blue'>For conductive sample we can get a better contrast by tuning the energy to an absorption edge for one of the element contained in the sample.
- <font color='blue'>For insulator, there will be a good contrast no matter the energy since the sample plate is conductive while the sample is not (sample appears as a "hole" in the drain current).
- <font color='blue'>we can go in specular condition and look at the intesity of the reflected beam on the detector; the sample will give a good signal while the sample plate, which is a very bad mirror, will not. This works well for flat samples but not for facetted sample.
<font color='blue'>We use the second method here:
### Align x:
```python
scanx(-5000,5000,250) # absolute x scan
Scan1: 29idKappa:m2.VAL= -5000.0 / 5000.0 / 250.0
Kappa_17 started at Tue 27 Jul 2021 14:29:50
Kappa_17 finished at Tue 27 Jul 2021 14:31:45
```python
plot_mda(17,34,title='x scan in specular th2th=5/10')
```python
mvx(600) # we move to the center of the sample
x = 599.992
### Align y:
```python
scany(-5000,5000,250) # absolute y scan
Scan1: 29idKappa:m3.VAL= -5000.0 / 5000.0 / 250.0
Kappa_18 started at Tue 27 Jul 2021 14:32:31
Kappa_18 finished at Tue 27 Jul 2021 14:34:27
```python
plot_mda(18,34,title='y scan in specular th2th=5/10')
```python
mvy(2000)
y = 1999.997
#### <font color='blue'>Why is the y scan so broad?
<font color='blue'>The sample size is convoluted with the beam and in the horizontal scattering plan, th footprint of the beam is very big at small angle: the beam horizontal size is about $400\mu m$; the y is the axis along the beam for $th=0$, so at $th=5^{\circ}$, the footprint of the beam is $0.4 / sin(5) = 4.5 mm$
```python
0.4/sin(5*pi/180)
4.589485298267943
### Align chi:
<font color='blue'>Finally we can check chi (tilt of the sample out of the horizontal scattering plane). Our detectors are all at least 10 mm tall, so this does not need to be super accurate. We can do that by looking at specular and rocking chi:
```python
uan(20,10+th0)
tth=20 th=8.19
```python
dscanchi(-5,5,0.5)
Scan1: 29idKappa:Euler_Chi= 83.8 / 93.8 / 0.5
Kappa_21 started at Tue 27 Jul 2021 14:52:36
Kappa_21 finished at Tue 27 Jul 2021 14:53:40
```python
plot_mda(21,34,title='chi scan in specular th2th=10/20')
# Define sample lattice:
<font color='blue'>We are ready to look for Bragg peaks. First we need to "create" a new sample, here $La_{0.7}Ca_{0.3}MnO_3$:
```python
sampleNew('LCMO',5.43,5.43,7.7,90,90,90) # name, a, b, c, alpha, beta, gamma
HklSample(name='LCMO', lattice=LatticeTuple(a=5.43, b=5.43, c=7.7, alpha=90.0, beta=90.0, gamma=90.0), ux=Parameter(name='None (internally: ux)', limits=(min=-180.0, max=180.0), value=0.0, fit=True, inverted=False, units='Degree'), uy=Parameter(name='None (internally: uy)', limits=(min=-180.0, max=180.0), value=0.0, fit=True, inverted=False, units='Degree'), uz=Parameter(name='None (internally: uz)', limits=(min=-180.0, max=180.0), value=0.0, fit=True, inverted=False, units='Degree'), U=array([[1., 0., 0.],
[0., 1., 0.],
[0., 0., 1.]]), UB=array([[ 1.15712437e+00, -7.08534325e-17, -4.99654726e-17],
[ 0.00000000e+00, 1.15712437e+00, -4.99654726e-17],
[ 0.00000000e+00, 0.00000000e+00, 8.15998092e-01]]), reflections=[], reflection_measured_angles=array([], shape=(0, 0), dtype=float64), reflection_theoretical_angles=array([], shape=(0, 0), dtype=float64)))
# Define initial UB matrix:
<font color='blue'>According to the sample grower, our sample is align as follow:
```python
plot_image('/home/beams/29IDUSER/Documents/User_Folders/Staff/Figures/sample.png',h=5)
## Reflection 1:
<font color='blue'>The easiest reflection to define is what is called "out of plane" (ie sample normal), here [100].
To probe this direction, we just need to align the q vector along the sample normal, ie $tth = 2 * th$:
<font color='blue'>To satisfy Bragg's law, we need to match the energy with the lattice parameter (distance between 2 crystallographic planes $d$).
```python
plot_image('/home/beams/29IDUSER/Documents/User_Folders/Staff/Figures/BraggLaw.png', h=8)
<font color='blue'> This requires to work at high enough energy (see Ewald's sphere construction: https://en.wikipedia.org/wiki/Ewald%27s_sphere for more details):
```python
energy(2850)
ID Ready
ID SET : 2953.0 eV
ID RBV : 2952.1 eV
Down Table
Mono set to 2850 eV
Mono set to 2850 eV
align_m3r()
Starting...
Done
(position, sigma, total intensity, integration time (s), mirror pitch):
(135.9, 6.64, 31805.0, 0.03, -16.4465)
Starting...
Done
(119.26, 6.7, 28111.0, 0.03, -16.4636)
<font color='blue'> Our sample normal has a -1.81 degree offset (th0) with respect to the diffractometer (e.g. glue under the sample, burr on the sample plate), which we need to take into acount in order to align our sample normal to the q vector:
```python
uan(80,40+th0) # uan(tth,th) moves th and tth simultaneously; here th = tth/2+th0
tth=80 th=38.19
<font color='blue'> We define a reflection (r1) for the current motor positions; (100) is forbiden, we use (200) instead:
```python
r1=setor(2,0,0) # setor(h,k,l) defines a reflection using the current motor positions
tth=80.000, omega=38.190, chi=88.800, phi=0.000
<font color='blue'> We need a second reflection in order to fully define the UB matrix.This can be done many different ways:
- <font color='blue'> If we move away from the th2th condition by moving the sample to th+delta while tth (detector) is kept fixed, we have a contribution from an in-plane axis (in our case, [010]): for th+delta, q is now along [1-delta, delta, 0] (left figure).
- <font color='blue'> by going to th = 120 and tth = th/2, q is along [0,1,0] (right figure)
<font color='blue'> <p>Note that the actual values of the miller indexes do not matter at this point; it can be refined later. Besides, we will be working along the out-of-plane direction for the rest of this experiment so the in-plane alignment is secondary.
```python
r1=setor(2,0,0,38.19,80,88,0)
tth=38.190, omega=80.000, chi=88.000, phi=0.000
```python
r2=setor(0,2,0,60,120,88,0) # we define this new position as hkl=(2,2,0)
tth=60.000, omega=120.000, chi=88.000, phi=0.000
```python
UBcalc(r1,r2) # compute UB matric using the 2 reflections we have defined
UB Matrix forLCMO:
[[ 1.01111223e+00 5.62662285e-01 -7.10564275e-17]
[ 5.62319526e-01 -1.01049629e+00 2.84779227e-02]
[ 1.96366305e-02 -3.52873081e-02 -8.15501008e-01]]
array([[ 1.01111223e+00, 5.62662285e-01, -7.10564275e-17],
[ 5.62319526e-01, -1.01049629e+00, 2.84779227e-02],
[ 1.96366305e-02, -3.52873081e-02, -8.15501008e-01]])
<font color='blue'> The "where" function gives a snapshot of where everything is, in real space and reciprocal space (based on the current position of the motors and energy of the beamline)
```python
wh()
LAMBDA = 4.350 hv = 2849.954
Sync to motor:
omega = 36.99978 chi = 88.80012 phi = 0.00001
tth = 79.99970 kth = 92.25599 kap = 131.94400 kphi = 55.25622
Calculating Kappa angles using kth0 = 57.045
term value
diffractometer fourc
Sample LCMO
a 5.43
b 5.43
c 7.7
wavelength (angstrom) 4.350393146474888
energy (eV) 2849.953919692616
h 1.604256411568741
k 0.033324264813703756
l 1.5184151818638708e-12
omega 36.99977609685484
chi 88.80011730447826
phi 1.0183568284702227e-05
tth 79.99970000000002
kth 92.256
kap 131.944
kphi 55.256
# Navigating in reciprocal space:
<font color='blue'> We can now calculate the position of the motors for any given hkl:
```python
cahkl(2,0,0) # calculate the motor position for a given hkl; the
Sample = LCMO
Lattice = 5.430,5.430,7.700
Mode = constant_phi
(51.43261, 88.80012, 1e-05, 106.48536, 106.689, 131.944, 55.256)
<font color='blue'> This is a coarse estimation (all we did so far was to align q along the sample normal), but we can easily refine the position by looking at the image on the MCP then tweak the motors to center the beam on the detector:
```python
setdet('mcp')
Detector now set to: mcp
```python
plot_image('/home/beams/29IDUSER/Documents/User_Folders/Staff/Screenshots/h68p57_tth135p155_hv951p5.png',h=8)
```python
uan(106.5,52.4) # centers the beam on the MCP
tth=106.5 th=52.4
<font color='blue'> Since we only aligned coarsely, we are most likely just catching the tail of the Bragg peak. A Bragg reflection give a lot of signal so we switch back to the big diode:
```python
setdet('d3')
```python
mvtth(108.6)
tth = 108.6
<font color='blue'> We rock theta while maintaining tth so that the peak is centered on the detector:
```python
dscanth(-1,1,0.05)
Scan1: 29idKappa:Euler_Theta= 51.4 / 53.4 / 0.05
Kappa_22 started at Tue 27 Jul 2021 15:34:50
Kappa_22 finished at Tue 27 Jul 2021 15:35:27
```python
plot_mda(22,33)
<font color='blue'> We scan a bit lower in th:
```python
dscanth(-3,-1,0.05)
Scan1: 29idKappa:Euler_Theta= 49.4 / 51.4 / 0.05
Kappa_23 started at Tue 27 Jul 2021 15:36:26
Kappa_23 finished at Tue 27 Jul 2021 15:37:04
```python
plot_mda(22,33,23,33, color='b', filepath=path,prefix='Kappa_')
/home/beams/29IDUSER/Documents/User_Folders/Stoica/lastfigure.png
<font color='blue'> Moving th to the maximum intensity:
```python
mvth(51.5)
th = 51.504
<font color='blue'> We are now sufficiently close to start scanning in hkl. Let start with scanning from (1.9,0,0) to (2,0,0):
```python
scanhkl((1.9,0,0),(2.1,0,0),51,ct=1) # hkl_start, hkl_stop, number of point, acquisition time
Current energy: 2849.95
Number of accessible reflections: 52
Integration time set to: 1
<H> = [D46]
<K> = [D47]
<L> = [D48]
tth = [D54]
= [D55]
= [D56]
= [D57]
Scan1: 29idKappa:m9.VAL= 0.0 / 0.0 / 0.0
Kappa_26 started at Tue 27 Jul 2021 15:46:30
Kappa_26 finished at Tue 27 Jul 2021 15:48:13
All extra positionners cleared
```python
plot_mda(24,33,vs_det=46,filepath=path,prefix='Kappa',save=False)
<font color='blue'> Let zoom in:
```python
scanhkl((1.95,0,0),(2.01,0,0),51,ct=1)
<H> = [D46]
<K> = [D47]
<L> = [D48]
tth = [D54]
= [D55]
= [D56]
= [D57]
```python
plot_mda(26,33,vs_det=46,filepath=path,prefix='Kappa',save=False)
<font color='blue'> The diode is saturating (Bragg peaks are very strong); we adjust the gain:
```python
plot_mda(27,33,vs_det=46)
```python
mvth(51.5)
th = 51.5
```python
mvtth(106.6)
tth = 106.599
```python
scanhkl((1.99,0,0),(2.01,0,0),51,ct=1)
Current energy: 2849.99
<H> = [D46]
<K> = [D47]
<L> = [D48]
tth = [D54]
= [D55]
= [D56]
= [D57]
Kappa_27 started at Tue 27 Jul 2021 15:52:40
Kappa_27 finished at Tue 27 Jul 2021 15:54:11
```python
fit_mda(24,33,0.0001,'lorz','H',filepath=path,prefix='Kappa_')
Amplitude: 962119.4905293721
Center: 2.0011564734389253
FWHM: 0.0032155301978673777
2.0011564734389253
<font color='blue'> Our Bragg peak is resonably centered at (2,0,0); we can extract the corresponding motor position to refine our UB matrix:
```python
fit_mda(24,33,1,'lorz','tth',filepath=path,prefix='Kappa_')
Amplitude: 956983.1664632442
Center: 106.57372905487838
FWHM: -0.24795625000545865
106.57372905487838
```python
fit_mda(24,33,1,'lorz','th',filepath=path,prefix='Kappa_')
Amplitude: 949311.2170990376
Center: 51.47765757272533
FWHM: -0.12363409890061101
51.47765757272533
<font color='blue'> We move to the corresponding motor position and redefine our 1st reflection and recalculate the UB matrix:
```python
mvth(51.485)
th = 51.489
```python
mvtth(106.596)
tth = 106.596
```python
r1=setor(2,0,0) # refine r1
tth=106.596, omega=51.485, chi=88.700, phi=0.000
```python
UBcalc(r1,r2) #
UB Matrix forLCMO:
[[-3.66128024e-02 -1.15654498e+00 -1.83739257e-08]
[ 1.15624728e+00 -3.66033772e-02 -1.85135437e-02]
[ 2.62399455e-02 -8.30705326e-04 8.15788045e-01]]
LAMBDA = 19.222 hv = 644.998
Sync to motor:
omega = 49.99983 chi = 88.69996 phi = 0.00018
tth = 106.59610 kth = 105.11199 kap = 131.71500 kphi = 55.11234
array([[-3.66128024e-02, -1.15654498e+00, -1.83739257e-08],
[ 1.15624728e+00, -3.66033772e-02, -1.85135437e-02],
[ 2.62399455e-02, -8.30705326e-04, 8.15788045e-01]])
<font color='blue'> We are now perfectly align on the (2,0,0):
```python
wh()
LAMBDA = 4.350 hv = 2849.959
Sync to motor:
omega = 51.48483 chi = 88.69996 phi = 0.00032
tth = 106.59610 kth = 106.59699 kap = 131.71500 kphi = 55.11248
term value
Sample LCMO
a 5.43
b 5.43
c 7.7
wavelength (angstrom) 4.350384657744499
energy (eV) 2849.9594806929294
h 2.001446605114393
k 1.1270021960968891e-07
l -2.2281850186939006e-07
omega 51.48483210423717
chi 88.69996056606675
phi 0.0003214309506084944
tth 106.59610000000002
kth 106.597
kap 131.715
kphi 55.112
# Resonance:
<font color='blue'> In order to measure long range ordering with element specificity (magnetic, orbital or charge ordering), we need to go at the resonance, here the Mn L-edges (L2 = 650 eV, L3 = 639 eV):
```python
energy(645) # We set our energy right in between the 2 edges
ID Ready
ID SET : 658.7 eV
ID RBV : 653.5 eV
Down Table
Mono set to 645 eV
Mono set to 645 eV
align_m3r()
Starting...
Done
(119.02, 8.99, 107333.0, 0.001, -16.451)
<font color='blue'> We scan the energy:
```python
scanhv(620,670,0.25) # start, stop, step
Scan1: 29idmono:ENERGY_SP= 620.0 / 670.0 / 0.25
Kappa_28 started at Tue 27 Jul 2021 16:09:39
Kappa_28 finished at Tue 27 Jul 2021 16:16:24
Mono set to 645.0 eV
<font color='blue'> Raw spectrum:
- <font color='blue'>blue is the drain current (Total Electron Yield or TEY)
- <font color='blue'>orange is the I0 (monitor)
```python
plot_mda(28,32,28,31,norm=1)
<font color='blue'> Normalized spectrum (TEY/I0):
```python
plot_mda(28,36)
<font color='blue'> With cooling, we would then go to the resonant energy (640.5 eV) and look for the orbital peak located at (0.5,0,0):
```python
cahkl(0.5,0,0) #
Sample = LCMO
Mode = constant_phi
(60.43961, 88.69995, 0.00018, 124.50566, 115.552, 131.715, 55.112)
```python
%run Macros_29id/ScanFunctions_plot.py
/home/beams22/29IDUSER/Documents/User_Macros/Macros_29id/ScanFunctions_plot.py
```python
<br>
<br>
# Experiment set-up
# Experiment set-up
