Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
I
iexcode
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Iterations
Wiki
Code
Merge requests
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Locked files
Build
Pipelines
Jobs
Pipeline schedules
Artifacts
Deploy
Releases
Package Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Code review analytics
Issue analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
Community forum
Contribute to GitLab
Provide feedback
Terms and privacy
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
29id
iexcode
Commits
187aab91
Commit
187aab91
authored
2 years ago
by
29iduser
Browse files
Options
Downloads
Patches
Plain Diff
debug
parent
433d2a28
No related branches found
Branches containing commit
No related tags found
Tags containing commit
No related merge requests found
Changes
3
Hide whitespace changes
Inline
Side-by-side
Showing
3 changed files
iexcode/instruments/utilities.py
+0
-10
0 additions, 10 deletions
iexcode/macros/start_of_the_week.py
+41
-18
41 additions, 18 deletions
requirements.txt
+2
-0
2 additions, 0 deletions
requirements.txt
with
43 additions
and
28 deletions
0
10
View file @
187aab91
@@ -70,16 +70,6 @@ def input_timeout(question,t):
else
else
print
You said nothing!
print
You said nothing!
def
playsound
sound
FF
FF
Final Fantasy victory sound
ding
a subtle ding noise
hallelujah
hallelujah chorus
train
train whistle
drumroll
beepboop
play_sound
sound
def
play_sound
sound
train
def
play_sound
sound
train
This diff is collapsed.
41
18
View file @
187aab91
@@ -22,6 +22,23 @@ global m3r_camNum
m3r_camNum
6
m3r_camNum
6
def
sotw
grt
branch
wait
False
kwarg
def
sotw
grt
branch
wait
False
kwarg
This should be run every at the start of every week.
If wait=True, wait for next day a 8:05.
**kwargs:
mode: polarization, default => RCP
repeat: True/False
True => doesn
t do any initialization
False => resets everything (switches branch and grating)
scanType = [
slit1
wire
monoVslit
flux
sound: plays sound when a scantype is completed, default => True
# for individiual scantypes
slit1A_extended: to take a larger range, default => False
monoVslit_quick:
True => takes a single line cut (default)
False =>
StartOfTheWeek
grt
branch
wait
wait
kwarg
StartOfTheWeek
grt
branch
wait
wait
kwarg
def
default_detectors
branch
def
default_detectors
branch
@@ -54,7 +71,9 @@ def interactive_fct():
if
flag
1
if
flag
1
print
\n
resuming script...
\n
print
\n
resuming script...
\n
if
flag
2
if
flag
2
print
\n
repeating scan...
\n
print
\n
repeating scan...
\n
if
flag
return
return
flag
return
flag
def
input2float
ask
default_x
0
def
input2float
ask
default_x
0
@@ -129,6 +148,8 @@ def interactive_fit_mda(val_name,scannum,det,FWHM_or_PolyOrder,fct,**kwargs):
position
fit_mda
scannum
det
FWHM_or_PolyOrder
fct
xrange
x1
x2
position
fit_mda
scannum
det
FWHM_or_PolyOrder
fct
xrange
x1
x2
plt
show
plt
show
flagfit
2
flagfit
2
if
flatfit
return
return
flagfit
position
return
flagfit
position
def
sotw_BLinit
branch
def
sotw_BLinit
branch
@@ -215,11 +236,11 @@ def sotw_ID_steering(detCA4,**kwargs):
scanNum_v
last_mda
scanNum_v
last_mda
flagfit
h
interactive_fit_mda
H_center
scanNum_h
detCA4
1
gauss
xrange
1
1
flagfit
h
interactive_fit_mda
H_center
scanNum_h
detCA4
1
gauss
xrange
1
1
if
flagfit
if
flagfit
or
flag
0
return
return
flagfit
v
interactive_fit_mda
V_center
scanNum_v
detCA4
1
gauss
xrange
1
1
flagfit
v
interactive_fit_mda
V_center
scanNum_v
detCA4
1
gauss
xrange
1
1
if
flagfit
if
flagfit
or
flag
0
return
return
try
try
ID_steering_message
h
v
ID_steering_message
h
v
@@ -298,22 +319,24 @@ def sotw_slit_vs_mono(slit_name,**kwargs):
FMB_mirror_move
1
RZ
new_roll
FMB_mirror_move
1
RZ
new_roll
sleep
2
sleep
2
FMB_mirror_get
1
FMB_mirror_get
1
print
\n
repeating scans...
#update M1 dictionary
foo
input
Do you want to update the M1 (y or n)? >
if
foo
0
lower
y
try
#update_mirror_dict(1)
print_warning_message
need to debug update_mirror_dict, do by hand
except
couldn
t update the mirror dictionary, do by hand
if
flag
return
flag
2
flag
2
except
except
print
\invalid input; unable to move M1
print
flag
interactive_fct
flag
interactive_fct
print
\n
repeating scans...
foo
input
if
foo
0
lower
y
try
except
couldn
if
flag
return
return
flag
v
h
return
flag
v
h
@@ -428,7 +451,7 @@ def StartOfTheWeek(grt,branch,wait=False,**kwargs):
flag
2
flag
2
while
flag
1
while
flag
1
flag
sotw_ID_steering
detCA4
kwargs
flag
sotw_ID_steering
detCA4
kwargs
if
flag
if
flag
or
flag
0
return
return
diagnostic
mesh_W
out
diagnostic
mesh_W
out
@@ -437,7 +460,7 @@ def StartOfTheWeek(grt,branch,wait=False,**kwargs):
if
wire
in
kwargs
scanType
if
wire
in
kwargs
scanType
print
\n\n
================== Slit 1A scans:
print
\n\n
flag
sotw_wire
detH
detV
kwargs
flag
sotw_wire
detH
detV
kwargs
if
flag
if
flag
or
flag
0
return
return
###### Mono/slit scans:
@@ -454,7 +477,7 @@ def StartOfTheWeek(grt,branch,wait=False,**kwargs):
print
\n\n
================== Mono/slit scans:
print
\n\n
flag
sotw_slit_positions
grt
kwargs
flag
sotw_slit_positions
grt
kwargs
if
flag
if
flag
or
flag
0
return
return
requirements.txt
2
0
View file @
187aab91
@@ -7,3 +7,5 @@ netCDF4
pyepics
pyepics
playsound
#pygobject
\ No newline at end of file
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
