Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
X
xxx-R6-1
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Iterations
Wiki
Code
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Locked files
Deploy
Releases
Model registry
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Issue analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
Community forum
Contribute to GitLab
Provide feedback
Terms and privacy
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
synApps_6_1_Working
xxx-R6-1
Commits
f29395b0
Commit
f29395b0
authored
21 years ago
by
rivers
Browse files
Options
Downloads
Patches
Plain Diff
More changes for 3.14.5
parent
9636f64f
No related branches found
No related tags found
No related merge requests found
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
iocBoot/iocvxWorks/st.cmd
+103
-59
103 additions, 59 deletions
with
103 additions
and
59 deletions
103
59
View file @
f29395b0
vxWorks
startup
script
vxWorks
startup
script
If
using
a
PowerPC
CPU
with
more
than
32
MB
of
memory
and
not
building
with
longjump
then
allocate
enough
memory
here
to
force
code
to
load
in
lower
32
MB
mem
malloc
1024
1024
96
for
vxStats
for
vxStats
#putenv
"engineer=not me"
#putenv
"engineer=not me"
@@ -22,36 +18,30 @@ cd topbin
be
added
before
any
C
code
is
loaded
see
SPR
#28980
be
added
before
any
C
code
is
loaded
see
SPR
#28980
sysCplusEnable
1
sysCplusEnable
1
If
using
a
PowerPC
CPU
with
more
than
32
MB
of
memory
and
not
building
with
longjump
then
allocate
enough
memory
here
to
force
code
to
load
in
lower
32
MB
mem
malloc
1024
1024
96
Load
custom
EPICS
software
from
user
tree
and
from
share
Load
custom
EPICS
software
from
user
tree
and
from
share
ld
xxx
.munch
ld
xxx
.munch
Increase
size
of
buffer
for
error
logging
from
default
1256
errlogInit
5000
Note
that
you
need
an
MPF
router
not
only
for
IP
modules
but
also
for
the
AIM
MCA
support
and
other
MPF
servers
routerInit
routerInit
talk
to
local
IP
's
localMessageRouterStart
0
0
talk
to
IP
's on satellite processor
talk
to
IP
# (must agree with tcpMessageRouterServerStart in st_proc1.cmd)
# for IP modules on stand-alone mpf server board
#tcpMessageRouterClientStart(1, 9900, Remote_IP, 1500, 40)
For
processor
with
IP
slots
or
that
runs
a
dumb
IP
carrier
#ld
ip
.munch
#ld
mpfgpibserver
.munch
#ld
mpfserialserver
.munch
#ld
dac128V
.munch
#ld
ip330
.munch
#ld
ip330Serv
.munch
#ld
ipUnidig
.munch
#ld
loveServer
.o
#ld
mpcServer
.o
# This IOC configures the MPF server code locally
#cd
startup
cd startup
st_mpfserver
.cmd
< st_mpfserver.cmd
#cd
topbin
cd topbin
For
local
OR
remote
GPIB
server
Can
't use both (as of mpfGpib1.4)
#ld < GpibHideosLocal.o
#ld < GpibHideosRemote.o
### dbrestore setup
### dbrestore setup
# ok to restore a save set that had missing values (no CA connection to PV)?
@@ -70,7 +60,14 @@ set_requestfile_path(ipunidig, "ipUnidigApp/Db")
set_requestfile_path(dac128v, "dac128VApp/Db")
set_requestfile_path(motor, "motorApp/Db")
set_requestfile_path(std, "stdApp/Db")
set_requestfile_path(quadem, "quadEMApp/Db")
#set_requestfile_path(camac, "camacApp/Db")
reboot_restoreDebug=0
# specify what save files should be restored. Note these files must be reachable
# from the directory current at the time iocInit is run
set_pass0_restoreFile("auto_positions.sav")
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
# override address, interrupt vector, etc. information in module_types.h
#module_types()
#module_types()
@@ -103,7 +100,7 @@ dbLoadRecords("$(CALC)/calcApp/Db/interp.db", "P=xxx:")
supported
by
a
customized
version
of
the
SNL
program
written
by
Pete
Jemian
supported
by
a
customized
version
of
the
SNL
program
written
by
Pete
Jemian
#dbLoadRecords
"$(OPTICS)/opticsApp/Db/xia_slit.db"
"P=xxx:, HSC=hsc1:"
#dbLoadRecords
"P=xxx:, HSC=hsc1:"
#dbLoadRecords
"P=xxx:, HSC=hsc2:"
#dbLoadRecords
"P=xxx:, HSC=hsc2:"
#dbLoadRecords
"$(IP)/ipApp/Db/generic_serial.db"
"P=xxx:,C=0,
IPSLOT=a,CHAN=6,BAUD=9600,PRTY=None,DBIT=8,SBIT=1
#dbLoadRecords
"P=xxx:,C=0,
SERVER=serial7
Pico
Motors
Ernest
Williams
MHATT
-CAT
Pico
Motors
Ernest
Williams
MHATT
-CAT
Motors
see
picMot
.substitutions
in
same
directory
as
this
file
Motors
see
picMot
.substitutions
in
same
directory
as
this
file
@@ -118,7 +115,7 @@ dbLoadRecords("$(STD)/stdApp/Db/IDctrl.db","P=xxx:,xx=02us")
test
generic
gpib
record
test
generic
gpib
record
#dbLoadRecords
"$(STD)/stdApp/Db/gpib.db"
"P=xxx:"
#dbLoadRecords
"P=xxx:"
test
generic
camac
record
test
generic
camac
record
#dbLoadRecords
STD)/std
App/Db/camac.db"
"P=xxx:"
#dbLoadRecords
CAMAC)/camac
App/Db/camac.db"
"P=xxx:"
@@ -153,8 +150,8 @@ oms58Setup(3, 8, 0x3000, 190, 5, 10)
1
controller
being
configured
1
controller
being
configured
2
port
type
0
-GPIB
_PORT
or
1
-RS
232
_PORT
2
port
type
0
-GPIB
_PORT
or
1
-RS
232
_PORT
3
GPIB
link
or
MPF
server
location
3
GPIB
link
or
MPF
server
location
4
GPIB
address
or
hideos_task
name
4
GPIB
address
int
or
mpf
serial
server
name
string
#MM4000Config
0
1
1
a-S
erial
[0]
#MM4000Config
0
1
1
s
erial
2
Newport
PM500
driver
setup
parameters
Newport
PM500
driver
setup
parameters
1
maximum
number
of
controllers
in
system
1
maximum
number
of
controllers
in
system
@@ -165,10 +162,33 @@ oms58Setup(3, 8, 0x3000, 190, 5, 10)
Newport
PM500
configuration
parameters
Newport
PM500
configuration
parameters
1
card
being
configured
1
card
being
configured
2
port
type
0
-GPIB
_PORT
1
-RS
232
_PORT
2
port
type
0
-GPIB
_PORT
1
-RS
232
_PORT
3
link
for
GPIB
or
hideos_card
for
RS
232
3
GPIB
link
or
MPF
server
location
3
GPIB
link
or
MPF
server
location
4
GPIB
address
int
or
mpf
serial
server
name
string
4
GPIB
address
int
or
mpf
serial
server
name
string
#PM500Config
0
1
1
"a-Serial[4]"
#PM500Config
0
1
1
"serial3"
McClennan
PM304
driver
setup
parameters
1
maximum
number
of
controllers
in
system
2
maximum
number
of
channels
on
any
controller
3
motor
task
polling
rate
min
1
Hz
max
60
Hz
#PM304Setup
1
1
10
McClennan
PM304
driver
configuration
parameters
1
controller
being
configured
2
MPF
server
location
3
MPF
serial
server
name
string
#PM304Config
0
0
"serial4"
ACS
MCB
4
B
driver
setup
parameters
1
maximum
number
of
controllers
in
system
2
maximum
number
of
axes
per
controller
3
motor
task
polling
rate
min
1
Hz
max
60
Hz
#MCB4BSetup
1
4
10
ACS
MCB
4
B
driver
configuration
parameters
1
controller
being
configured
2
MPF
server
location
3
MPF
server
name
string
#MCB4BConfig
0
0
"serial5"
A
set
of
scan
parameters
for
each
positioner
This
is
a
convenience
A
set
of
scan
parameters
for
each
positioner
This
is
a
convenience
for
the
user
It
can
contain
an
entry
for
each
scannable
thing
in
the
for
the
user
It
can
contain
an
entry
for
each
scannable
thing
in
the
@@ -182,7 +202,7 @@ dbLoadRecords("$(VME)/vmeApp/Db/Jscaler.db","P=xxx:,S=scaler1,C=0")
Joerger
VSC
setup
parameters
Joerger
VSC
setup
parameters
1
cards
2
base
address
ext
256
-byte
boundary
1
cards
2
base
address
ext
256
-byte
boundary
3
interrupt
vector
0
disable
or
64
255
3
interrupt
vector
0
disable
or
64
255
VSCSetup
1
0x
9
0000000
200
VSCSetup
1
0x
B
0000000
200
Allstop
alldone
Allstop
alldone
This
database
must
agree
with
the
motors
and
other
positioners
you
've actually loaded.
This
database
must
agree
with
the
motors
and
other
positioners
you
@@ -192,50 +212,50 @@ dbLoadRecords("$(STD)/stdApp/Db/all_com_16.db","P=xxx:")
### Scan-support software
# crate-resident scan. This executes 1D, 2D, 3D, and 4D scans, and caches
# 1D data, but it doesn'
t
store
anything
to
disk
See
'saveData'
below
for
that
t
store
anything
to
disk
See
'saveData'
below
for
that
dbLoadRecords
"$(S
TD)/std
App/Db/scan.db"
"P=xxx:,MAXPTS1=4000,MAXPTS2=200,MAXPTS3=10,MAXPTS4=10,MAXPTSH=4000"
dbLoadRecords
"$(S
SCAN)/sscan
App/Db/scan.db"
Slits
Slits
dbLoadRecords
STD)/std
App/Db/2slit.db"
"P=xxx:,SLIT=Slit1V,mXp=m3,mXn=m4"
dbLoadRecords
OPTICS)/optics
App/Db/2slit.db"
dbLoadRecords
STD)/std
App/Db/2slit.db"
"P=xxx:,SLIT=Slit1H,mXp=m5,mXn=m6"
dbLoadRecords
OPTICS)/optics
App/Db/2slit.db"
under
development
under
development
#dbLoadRecords
STD)/std
App/Db/2slit_soft.db"
"P=xxx:,SLIT=Slit2V,mXp=m13,mXn=m14"
#dbLoadRecords
OPTICS)/optics
#dbLoadRecords
STD)/std
"P=xxx:,SLIT=Slit2H,mXp=m15,mXn=m16"
#dbLoadRecords
OPTICS)/optics
2
-post
mirror
2
-post
mirror
#dbLoadRecords
STD)/std
App/Db/2postMirror.db"
"P=xxx:,Q=M1,mDn=m18,mUp=m17,LENGTH=0.3"
#dbLoadRecords
OPTICS)/optics
User
filters
User
filters
#dbLoadRecords
STD)/std
App/Db/filterMotor.db"
"P=xxx:,Q=fltr1:,MOTOR=m1,LOCK=fltr_1_2:"
#dbLoadRecords
OPTICS)/optics
#dbLoadRecords
STD)/std
"P=xxx:,Q=fltr2:,MOTOR=m2,LOCK=fltr_1_2:"
#dbLoadRecords
OPTICS)/optics
#dbLoadRecords
STD)/std
App/Db/filterLock.db"
"P=xxx:,Q=fltr2:,LOCK=fltr_1_2:,LOCK_PV=xxx:DAC1_1.VAL"
#dbLoadRecords
OPTICS)/optics
Optical
tables
Optical
tables
#tableRecordDebug
1
#tableRecordDebug
1
dbLoadRecords
STD)/std
App/Db/table.db"
"P=xxx:,Q=Table1,T=table1,M0X=m1,M0Y=m2,M1Y=m3,M2X=m4,M2Y=m5,M2Z=m6,GEOM=SRI"
dbLoadRecords
OPTICS)/optics
App/Db/table.db"
Monochromator
support
Monochromator
support
Kohzu
and
PSL
monochromators
Bragg
and
theta
/Y/Z
motors
Kohzu
and
PSL
monochromators
Bragg
and
theta
/Y/Z
motors
standard
geometry
geometry
1
standard
geometry
geometry
1
dbLoadRecords
STD)/std
App/Db/kohzuSeq.db"
"P=xxx:,M_THETA=m9,M_Y=m10,M_Z=m11,yOffLo=17.4999,yOffHi=17.5001"
dbLoadRecords
OPTICS)/optics
App/Db/kohzuSeq.db"
modified
geometry
geometry
2
modified
geometry
geometry
2
dbLoadRecords
STD)/std
App/Db/kohzuSeq.db"
"P=xxx:,M_THETA=m9,M_Y=m10,M_Z=m11,yOffLo=4,yOffHi=36"
dbLoadRecords
OPTICS)/optics
App/Db/kohzuSeq.db"
Heidenhain
ND261
encoder
for
PSL
monochromator
Heidenhain
ND261
encoder
for
PSL
monochromator
#dbLoadRecords
"$(IP)/ipApp/Db/heidND261.db"
"P=xxx:,C=0,IPSLOT=a,CHAN=0"
#dbLoadRecords
Heidenhain
IK320
VME
encoder
interpolator
Heidenhain
IK320
VME
encoder
interpolator
#dbLoadRecords
STD)/std
App/Db/IK320card.db"
"P=xxx:,sw2=card0:,axis=1,switches=41344,irq=3"
#dbLoadRecords
VME)/vme
#dbLoadRecords
STD)/std
"P=xxx:,sw2=card0:,axis=2,switches=41344,irq=3"
#dbLoadRecords
VME)/vme
#dbLoadRecords
STD)/std
App/Db/IK320group.db"
"P=xxx:,group=5"
#dbLoadRecords
VME)/vme
"P=xxx:,group=5"
#drvIK320RegErrStr
#drvIK320RegErrStr
Spherical
grating
monochromator
Spherical
grating
monochromator
dbLoadRecords
STD)/std
App/Db/SGM.db"
"P=xxx:,N=1,M_x=m7,M_rIn=m6,M_rOut=m8,M_g=m9"
dbLoadRecords
OPTICS)/optics
App/Db/SGM.db"
4
-bounce
high
-resolution
monochromator
4
-bounce
high
-resolution
monochromator
dbLoadRecords
STD)/std
App/Db/hrSeq.db"
"P=xxx:,N=1,M_PHI1=m9,M_PHI2=m10"
dbLoadRecords
OPTICS)/optics
App/Db/hrSeq.db"
#dbLoadRecords
STD)/std
App/Db/hrSeq.db"
"P=xxx:,N=2,M_PHI1=m11,M_PHI2=m12"
#dbLoadRecords
OPTICS)/optics
App/Db/hrSeq.db"
Canberra
AIM
Multichannel
Analyzer
Canberra
AIM
Multichannel
Analyzer
#mcaRecordDebug
1
#mcaRecordDebug
1
@@ -271,10 +291,19 @@ dbLoadRecords("$(MCA)/mcaApp/Db/mca.db","P=xxx:,M=mca1,INP=#C0 S0 @AIM1/2,DTYPE=
Initialize
ICB
software
and
create
a
new
ICB
server
Initialize
ICB
software
and
create
a
new
ICB
server
icbSetup
const
char
serverName
int
maxModules
int
queueSize
icbSetup
const
char
serverName
int
maxModules
int
queueSize
serverName
defined
here
must
agree
with
icbConfig
and
dbLoadRecords
commands
maxModules
Maximum
number
of
ICB
modules
that
this
server
will
control
queueSize
size
of
MPF
message
queue
for
this
server
100
should
be
plenty
icbSetup
"icb/1"
10
100
icbSetup
"icb/1"
10
100
Configure
the
new
ICB
server
Configure
an
ICB
module
on
this
server
icbConfig
const
char
serverName
int
module
int
enetAddress
int
icbAddress
icbConfig
const
char
serverName
int
module
int
etherAddr
int
icbAddress
serverName
defined
in
icbSetup
above
module
the
index
number
for
this
module
0
1
2
etherAddr
ethernet
address
of
AIM
module
icbAddress
ICB
address
of
this
module
set
with
internal
rotary
switch
0x0
0xF
icbConfig
"icb/1"
0
0x9AA
3
icbConfig
"icb/1"
0
0x9AA
3
In
dbLoadRecords
commands
for
ICB
devices
In
dbLoadRecords
commands
for
ICB
devices
@@ -284,17 +313,28 @@ icbConfig("icb/1", 0, 0x9AA, 3)
dbLoadRecords
"$(MCA)/mcaApp/Db/icb_adc.db"
"P=xxx:,ADC=icbAdc1,CARD=0,SERVER=icb/1,ADDR=0"
dbLoadRecords
#icbConfig
"icb/1"
2
0x9AA
2
#icbConfig
"icb/1"
1
0x9AA
2
#dbLoadRecords
"$(MCA)/mcaApp/Db/icb_hvps.db"
"P=xxx:,HVPS=icbHvps1,CARD=0,SERVER=icb/1,ADDR=
2
#dbLoadRecords
1
#icbConfig
"icb/1"
3
0x9AA
4
#icbConfig
"icb/1"
2
0x9AA
4
#dbLoadRecords
"$(MCA)/mcaApp/Db/icb_amp.db"
"P=xxx:,AMP=icbAmp1,CARD=0,SERVER=icb/1,ADDR=
4
#dbLoadRecords
2
icbTcaSetup
char
serverName
int
maxModules
int
queueSize
icbTcaSetup
char
serverName
int
maxModules
int
queueSize
icbTcaConfig
char
serverName
int
module
int
enetAddress
int
icbAddress
serverName
defined
here
must
agree
with
icbTcaConfig
and
dbLoadRecords
commands
maxModules
Maximum
number
of
TCA
modules
that
this
server
will
control
queueSize
size
of
MPF
message
queue
for
this
server
100
should
be
plenty
#icbTcaSetup
"icbTca/1"
3
100
icbTcaSetup
"icbTca/1"
3
100
icbTcaConfig
char
serverName
int
module
int
etherAddr
int
icbAddress
icbTcaConfig
"icbTca/1"
0
0x9AA
1
serverName
defined
in
icbTcaSetup
above
module
the
index
number
for
this
module
0
1
2
etherAddr
ethernet
address
of
AIM
module
icbAddress
ICB
address
of
this
module
set
with
internal
rotary
switch
0x0
0xF
#icbTcaConfig
"icbTca/1"
0
0x9AA
1
#dbLoadRecords
"$(MCA)/mcaApp/Db/icb_tca.db"
"P=xxx:,TCA=icbTca1,MCA=mca1,CARD=0,SERVER=icbTca/1,ADDR=0"
#dbLoadRecords
Load
13
element
detector
software
Load
13
element
detector
software
@@ -324,8 +364,12 @@ dbLoadRecords("$(MCA)/mcaApp/Db/icb_adc.db","P=xxx:,ADC=icbAdc1,CARD=0,SERVER=ic
STR7201Config
int
card
int
maxSignals
int
maxChans
int
1
enable
internal
25
MHZ
clock
STR7201Config
int
card
int
maxSignals
int
maxChans
int
1
enable
internal
25
MHZ
clock
#STR7201Config
0
8
1000
0
#STR7201Config
0
8
1000
0
Struck
as
EPICS
scaler
dbLoadRecords
"$(MCA)/mcaApp/Db/STR7201scaler.db"
"P=13LAB:,S=scaler2,C=0"
Acromag
IP330
in
sweep
mode
Acromag
IP330
in
sweep
mode
#dbLoadRecords
"P=xxx:,M=mADC_1,DTYPE=ip330Sweep,NCHAN=2048,INP=#C0 S0 @d-Ip330Sweep"
#dbLoadRecords
"P=xxx:,M=mADC_1,DTYPE=ip330Sweep,NCHAN=2048,INP=#C0 S0 @Ip330Sweep1"
#dbLoadRecords
"P=xxx:,M=mADC_2,DTYPE=ip330Sweep,NCHAN=2048,INP=#C0 S1 @Ip330Sweep1"
Stuff
for
user
programming
Stuff
for
user
programming
dbLoadRecords
"$(STD)/stdApp/Db/userCalcs10.db"
"P=xxx:"
dbLoadRecords
"P=xxx:"
This diff is collapsed.
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
